Systems parameters
    CLS2086
    Posts: 168 from 2005/8/25
    When I go the first time to the Systems parameters menu, that works. But at the 2nd time nothnig happen ?
    Any idea ?
    I use a fresh install of the last MOS PUP release over an older.
    Keep the Faith !
    VG 5000/A1000/500/500+/600/2000/1200PPC-GREX/1200PPC-ATEO/1200+1230-IVFPUSCSI/CD32/Pegasos 1 April1 G3/Pegasos 2 G4/ Ahtlon/K6-3/various funny machines too :-)
  • »07.03.06 - 10:17
    AmigaMancer
    Posts: 265 from 2005/8/25
    It never happened to me.
    Does this happen every time you try to do it?
    How much memory you have?
    Amiga 1200 user.
  • »07.03.06 - 13:53
    CLS2086
    now it happens all the time.
    I've just 128mb plugged.
    Keep the Faith !
  • »08.03.06 - 08:57
    kas1e
    Posts: 97 from 2005/10/31
    It was never happened with older releases of mos ? Becouse it looks as the same problem for me now.
  • »22.03.06 - 07:19
    CLS2086
    I just copy again all files and it works well now.
    Keep the Faith !
  • »02.04.06 - 20:19
