Problem installing Morphos on PPC603e+
    Aminux
    Posts: 3 from 2006/1/18
    When i try to boot the startup-sequence the Morphos PowerUP cd,i get this message"could not find module.rom"
    So i used the editor to change "kickstart=roms/rom3.1"
    But not even this made any change,need some help here please.Also i must mention that i only have 48megs of ram.
  • »22.01.06 - 17:22
    VooDoo
    Posts: 189 from 2005/8/24
    You need to change path to your MOS dir/partition..If you dont know how..please post here your startup-sequence and i will correct this for you!!
    A1200 sandwich
    uA1c/g3 800 mHz/256mb/160gb hdd/OS4.1 :-D
    Warp croatian Amiga portal :
  • »22.01.06 - 22:35
