Can't get MOS running un PUP either :-(
    Dragster
    Posts: 98 from 2005/11/6
    Hello mates,
    I have a BPPC + Bvision combo in my amiga 1200T and I wanted to try morphos this weekend 'cause I've had no time to do it since its release. I downloaded the image, burned the CD and made a partition in a new SCSI HD in the first 200 MB of space in it. This partition is the only bootable partition I left for this purpose and it's formatted with FastFileSystem (HD connected to the scsi controller of the bppc board). I copied the contents of the CD, removed 1 of my 128 MB simms and removed my algor board which has some OS3.9 modules in its flashrom. I checked the startup-sequence and user-startup files in morphos directory, it looks ok... ok, then, turned the machine off and on, the thing booted and reset after it loaded the morphos modules, but after that it does nothing, there's no signal in the monitor and it just won't boot. I've tried a lof of things, like adding these lines to the startup command (I read this in a thread here):
    "Remove the ramdebug and disableled options. Add "init initresident" to edebugflags"
    I've tried with different reset levels, same behavior.. I don't know what else to do.. my hardware is OK, it works like a charm with OS 3.9 and WOS/PUP apps, etc...
    any help will be appreciated,
    thanks!
    Dragster
  • »11.11.05 - 16:59
    VooDoo
    Posts: 189 from 2005/8/24
    heya..I send to you PM about moS problem..maybe help it!
    A1200 sandwich
    uA1c/g3 800 mHz/256mb/160gb hdd/OS4.1 :-D
    Warp croatian Amiga portal :
  • »12.11.05 - 12:39
