guru 080298b8
    godmar
    Posts: 1 from 2005/8/27
    Hallo, I'm trying MOS for PowerUP un my A4k, I have CyberstormPPC+CyberVisionPPC, I have installed MOS on an IDE hdd, then I made a cold reboot and then, when I boot from MOS, I receive a guru 80298b8.
    Some suggestions?
    Thanks, Pietro.
    I will build myself a copper tower
    With four ways out and no way in
    But mine the glory, mine the power
    (So I chose Amiga and GNU/Linux)
  • »27.08.05 - 09:05
    Markus_Bieler
    Posts: 19 from 2004/3/20
    Same Guru on my System. A4000T / CSPPC+CVPPC
    It starts, shows the cli, makes the reboit and GURUs
    Tried resetlevel from 1 to 7
    Markus
    :angel:
  • »15.10.05 - 12:15
    Markus_Bieler
    Finally MorphOS_PowerUP workshere.
    I had to use the CSPPC-scsi-controller and SFSfilesystem.
    It just didn't worked with the onboard A4kT-scsi-controller, neither with FFS nor with sfsfilesystem.
    :angel:
  • »12.11.05 - 11:07
