Is there a fusion way ?
    mugo
    Posts: 28 from 2005/8/28
    Hello Folks,
    I'm just wondering, if there's a way to make Fusion, or better yet, IFusion work in MOS PUP ?
    I guess the only problem would be the reserved memory that Fusion needs to work. I think it's difficult (impossible ?) to do such a thing in MOS ?
    It would be really great if i can emulate MacOS again . . .
    Regards,
    Marcelo.
  • »10.10.05 - 20:28
    DJBase
    Posts: 745 from 2003/4/6
    Well, there is at least a working port of BasiliskII available if this would help.
  • »10.10.05 - 20:36
    Posts: 1520 from 2003/2/24
    Fusion doesnt work. It uses low level hacking not supported by MorphOS. I dont know about IFusion but I suspect it wont work.
    There is Basilisk II but dual booting to AmigaOS and running ShapeShifter is the best option for PowerUp systems. Basilisk is practically a UAE but emulating Mac (UME?).
  • »10.10.05 - 20:56
