wheel problem! eeek
    VooDoo
    Posts: 189 from 2005/8/24
    ques about wheel on MOS pup...I try it works but not good :( only works when i run patch from SS (WBM) but not work correct..whan i run whell UP scrool work down..and reversely...and FreeWheel patch from Aminet dont work here.,..Any here have experience whit wheel on MOS?
    And yeah using PS2 optical mouse (5 buttons + 1 wheel) whit pS2 adapter...on oS3.9+bb2 work GREAT!
    A1200 sandwich
    uA1c/g3 800 mHz/256mb/160gb hdd/OS4.1 :-D
    Warp croatian Amiga portal :
  • »06.10.05 - 22:42
    CISC
    Posts: 619 from 2005/8/27
    Anything that delivers NewMouse events should work .. anyway, you didn't tell us what kind of adapter you are using...
    - CISC
  • »07.10.05 - 03:12
    VooDoo
    Using PS2 adapter home made..schema is from Aminet and in combination whit AOS3.9 and FreeWheel works perfect..
    I test NewMouse whit under mos whit mi mice..but dont work..and I read in doc whay dont work.." Q: Can i use a PS/2 mouse with NewMouse?
    A: No, you can't. You need a real RS232 mouse."
    A1200 sandwich
  • »07.10.05 - 11:38
