Bourriquet 0.2.8 and MOS 1.4.5 PuP
    VooDoo
    Posts: 189 from 2005/8/24
    ohh..I'am happy..After two days testing ..and whit rusback help..I have full working bourriquet 0.2.8 client on MorphOS 1.4.5 PowerUP version...yeah that is great news..Work good..look good..and all is good...hihi...that is all !!
    A1200 sandwich
    uA1c/g3 800 mHz/256mb/160gb hdd/OS4.1  :-D
    Warp croatian Amiga portal :
  • »20.09.05 - 15:41
    Posts: 1077 from 2003/3/24
    You can search and download files?
  • »20.09.05 - 21:51
    VooDoo
    Yeah..all the functions works great..connect..search..download..great apps!
    A1200 sandwich
  • »21.09.05 - 07:23
    AmigaMancer
    Posts: 265 from 2005/8/25
    Does this mean that you have found a solution for the slow internet connection or that you are not using a serial modem anymore?
    Amiga 1200 user.
  • »21.09.05 - 07:38
    VooDoo
    @AmigaMancer
    For now I only testing this apps on serial.device..But i near future I will surf via DSL bye bye modem :)
    PS.whit nativ serial device I have better speed..its faster than internam miamidx device
    A1200 sandwich
  • »21.09.05 - 08:16
    AmigaMancer
    But, the last you posted about this, you said that you couldn't connect with the native serial device. How did you manage to connect?
    I am still having trouble on this, so maybe you could help me.
    [ Edited by AmigaMancer on 2005/9/21 15:35 ]
    Amiga 1200 user.
  • »21.09.05 - 10:31
    VooDoo
    Ohh..yeah..I only make this changes and all works now...Copy 8n1.device.elf and serial.device.elf to moS/morphOS/devs (with orginal name .elf)..and in miamidx config only write "DEVS/serial.device" (without .elf) and works Ok..ah yeah and unit is 0...that is all!Try this and post here results!
    A1200 sandwich
  • »21.09.05 - 11:32
    AmigaMancer
    Oh, this is what i am trying all this time. :( Except that i'm testing it with miami and genesis, not miamiDX.
    Thanks anyway.
    Amiga 1200 user.
  • »21.09.05 - 12:15
    VooDoo
    :( hmm..dont know..try whit DX ..if you have IT!!
    A1200 sandwich
  • »21.09.05 - 15:05
    diezi7
    Posts: 167 from 2005/7/25
    Pegasos II G4 (not working)
    Powerbook G4 1.0 15"
  • »22.09.05 - 07:23
    Mi-Go
    Posts: 95 from 2003/9/18
  • »22.09.05 - 11:28
    AmigaMancer
    Well, i can connect nad search for files without any problem, but when i try to download a file, the server disconnects me after a few seconds. I have try several servers.
    Any ideas why?
    Amiga 1200 user.
  • »22.09.05 - 22:01
    Brumiga
    Posts: 268 from 2004/4/3
    Hello,
    @Diezi7, use this link http://prdownloads.sourceforge.net/amigift/amigift_v1.1.lha?download, lamp.mcc v11.2 is inside.
    Brumiga
  • »23.09.05 - 06:34
    diezi7
  • »23.09.05 - 10:27
