Editpad don't work on MosPup?
    Condor
    Posts: 99 from 2005/9/1
    I can't run any program with reaction gui from os3.9
    (Editpad,HDToolBox.....
    Any solution for this???
    Thanks.
  • »12.09.05 - 10:48
    DJBase
    Posts: 745 from 2003/4/6
    These apps using ReAction. Not possible with MorphOS.
  • »12.09.05 - 11:41
    Chain-Q
    Posts: 348 from 2003/10/12
    Actually, using Reaction libs are possible, but only with a hack into them, which removes an (useless) library version checking, IIRC. But i can't remember the exact details.
    [.Hosting AmigaSpirit.hu.]
  • »12.09.05 - 11:43
    DJBase
    You can use ReAction if you use the orig. Workbench instead of Ambient with hacking the workbench.library.
  • »12.09.05 - 13:47
    Miky060
    Posts: 694 from 2003/2/24
    DO NOT use HDToolBox. I fear you can go in troubles with your HD. Use the MOS SCSIConfig utility instead.
    Instead of Notepad you can use eNote from aminet (MUI based..) that is much better or WordPad (but is better the first..).
    In general avoid reaction programs and search for sostitutes. I think there is nomore Reaction tools that can't be deleted from everyone's HD and changed with a similar MUI app..
  • »12.09.05 - 16:55
