CD problems!
    VooDoo
    Posts: 189 from 2005/8/24
    eeeekkk..how I can mount CD under MOS? I start unitcontrol on mos and firts time not see my CDRW on list (unit 1) ..when I click rescan..CDRW is here..put CD in CDRW but nothing..no cd Icon on MOS?? any know how I can resolve this problem?
    eh and using FastATA controller..
    A1200 sandwich
    uA1c/g3 800 mHz/256mb/160gb hdd/OS4.1  :-D
    Warp croatian Amiga portal :
  • »03.09.05 - 09:10
    Posts: 3210 from 2003/3/5
    MorphOS mounts CDROMs automatically.If your drive is not on the first IDE port, it will NOT work in MorphOS. The Docs/MorphOS.readme clearly mentions this.
    [ Edited by jacadcaps on 2005/9/3 19:20 ]
  • »03.09.05 - 09:18
    VooDoo
    Strange..On 1 chanel I have HDD and CDRW..CDRW its UNIT 1 and that is good?
    A1200 sandwich
  • »03.09.05 - 09:30
    diezi7
    Posts: 167 from 2005/7/25
    Pegasos II G4 (not working)
    Powerbook G4 1.0 15"
  • »03.09.05 - 20:51
    VooDoo
    Very strange..my hdd is unit 0 CDRW unit 1..and don't work..grrr..I need CD on MOS..I dont live without CD :((((
    A1200 sandwich
  • »04.09.05 - 19:01
    DJBase
    Posts: 745 from 2003/4/6
    @ VooDoo
    Use SCSI, it works fine out of the box.
  • »05.09.05 - 08:11
    VooDoo
    I resolve problem whit CD..I just connect my CDRW on channel 2...and work great...yeah I using FastATA and channal 1 and 2..but in MOS docs I read that MOS dont support FastATA chanell 2...here works!
    A1200 sandwich
  • »05.09.05 - 13:35
