RTL8029pci.device for MOS powerUP
    Posts: 10 from 2005/8/28
    It is possible to use the RTL8029pci.device V1.5 original for the Grex in MOS ??, I have tried and does not work for me. :-(
    Miami get online but veeeery slow pings response and no traffic  :-?
    Thanks.
  • »29.08.05 - 11:03
    Posts: 1079 from 2003/3/24
    It should work if not try the OpenPCI drivers!
  • »29.08.05 - 16:45
    Kal-L
    Posts: 3 from 2005/8/27
    Yes, the 8029 drivers works with Grex but I advise you no to put your card on the 1st slot of your Grex, the connexion becomes very slow. The 8139 driver doesn't work for me, nonetheless.
  • »29.08.05 - 18:44
    Hey thx for your help.
    Ka1-L can you tell my if you own a 1200Grex OR an
    A4000D one.
    I believe the problems in the slots of GREX is related
    of 1200 models
    This show pci scan in my WB3.9:
    9/0.Sistema:> pciscan
    cybpci.library 2.2
    BoardObject 0x80133F4
    Bus 0 <CyberstormPPC GRex PCI> Slot 3 Function 0
    Vendor 0x121A <3dfx Interactive Inc> Device 0x5 <Voodoo3>
    -> All Voodoo3 chips, 3000
    Class 0x3 <Display Controller>
    SubClass 0x0 <PC Compatible>
    ProgInterface 0x0 <VGA>
    Command 0x3
    -> I/O Access
    -> Memory Access
    Base 0: Address 0x80000000 Size 0x2000000
    Base 1: Address 0x82000000 Size 0x2000000
    Base 2: Address 0xFFFA1000 Size 0x100
    BoardObject 0x80134E4
    Bus 0 <CyberstormPPC GRex PCI> Slot 4 Function 0
    Vendor 0x10EC <Realtek Semiconductor> Device 0x8029 <RTL8029>
    -> NE2000 compatible Ethernet
    Class 0x2 <Network Controller>
    SubClass 0x0 <Ethernet>
    ProgInterface 0x0 <>
    Command 0x3
    -> I/O Access
    -> Memory Access
    Base 0: Address 0xFFFA1100 Size 0x20
    The RTL8029 is in the slot 4 this is in the bottom of
    Grex near A4000PCB
    Ciao.
    Read you
  • »31.08.05 - 21:06
    CLS2086
    Posts: 168 from 2005/8/25
    Hi, check you riser card about the resistor implemantation problem !
    it's explicated in the Yahoo! Group GREX.
    A 8139S should be better for you !
    Keep the Faith !
    VG 5000/A1000/500/500+/600/2000/1200PPC-GREX/1200PPC-ATEO/1200+1230-IVFPUSCSI/CD32/Pegasos 1 April1 G3/Pegasos 2 G4/ Ahtlon/K6-3/various funny machines too  :-)
  • »01.09.05 - 07:41
