eMac 800MHz - Going Free
    Ploes
    Posts: 2 from 2012/11/17
    I have an eMac 800MHz taking up space.
    Need it moved.
    Fully working, currently running MacOS 9.2
    Free to a good home, delivery to Central Belt Scotland done for the price of fuel, further away done at cost.
    [ Edited by Ploes 17.11.2012 - 16:31 ]
  • »17.11.12 - 14:31
    stephen_robinson
    Posts: 746 from 2007/4/22
    Ignore, bad forum etiquette by me.
    [ Edited by stephen_robinson 17.11.2012 - 19:57 ]
  • »17.11.12 - 16:51
    Ploes wrote:,
    Need it moved.
    Not sure why this is posted on a MorphOS forum, since I am pretty sure this model is not supported and cannot run any version of MorphOS.
  • »17.11.12 - 17:55
    Ploes
    right, so no one tinkers and might want to try expanding the hardware that MorphOS runs on.
    MacOS 10.5 only runs on 867 and above, but I had that running on this.
    ITS FREE HARDWARE. Its offerd to the local MacOS user group to.
    Consider the offer removed due to the outstanding negativity given to someone trying to give somthing away for free.  :-x
    Its off to the dump then
  • »18.11.12 - 13:53
    Posts: 2579 from 2003/2/24
    The way things are done inside MorphOS ONLY team-members could add the model-identifier into the boot.img (which would be the absolute 1st step when getting MorphOS to run a new HW).
    You also haven't told us wether your 800MHz eMac is the Ati or NVidia variant (there are 0.0 drivers for anything NVidia).
    IMO (and really only IMO) any eMac, wether supported or not should be placed in a dumpster ....... I'd rather take a 400MHz Powermac !
  • »18.11.12 - 14:07
    stephen_robinson
    May I suggest Amibay to shift it? http://www.amibay.com/
    http://www.everymac.com/systems/apple/emac/specs/emac_800.html
    Almost certainly wouldn't be good for MorphOS as it'll have an nVidia graphics.
  • »18.11.12 - 14:11
    redrumloa
    Posts: 1424 from 2003/4/13
    It is a nice offer, but this model probably has built in Geforce GFX and will never run MorphOS. eMacs in general are typicaly seen as the 2nd least desirable hardware for MorphOS. You probably over estimate the MorphOS userbase. Worldwide there may about 1,000 users give or take. The number of active M<orphzone members are probably in the low hundreds. The chances of reaching someone local to you in Soctland is low.
    Welcome to Morphzone BTW. We are usually a friendly bunch so don't take anything personally. It is just that your kind offer just won't likely be taken up.
    Since you are here, have you used MorphOS? We're all mostly previously long time users of the Commodore Amiga, were you a Commodore Amiga user?
  • »18.11.12 - 14:13
    stephen_robinson
    stephen_robinson,
    No wait, some do have ATI
    https://www.everymac.com/systems/apple/emac/specs/emac_800_ati.html
    My bad
  • »18.11.12 - 14:16
    Posts: 1099 from 2004/9/23
    800Mhz eMac as well as the 1Ghz eMac have different hardware and are not supported.
    Only 1.25 and 1.42 Ghz models are supported.
    Geit
  • »18.11.12 - 21:22
