Soundblaster live wanted
    runequester
    Posts: 106 from 2010/1/11
    It seems this is the way to go for audio, so if anyone has a soundblaster live that'll fit in a G4 MDD power mac, I'd love to take it off your hands for a reasonable price.
    Amiga 1200 and G4 MDD MOS as my main computers.
  • »12.07.12 - 15:57
    redrumloa
    Posts: 1424 from 2003/4/13
    runequester,
    You specifically need a SoundBlaster Live! (with emu10kx chip). Be careful not to get one pulled from a Dell even if it has that exact chip part number as it is a totally different card. The dell part will usually be labeled Dell somewhere, but not necessarily always. The dell card will NOT work.
    [ Edited by redrumloa 12.07.2012 - 13:06 ]
  • »12.07.12 - 16:06
    Posts: 2579 from 2003/2/24
    Ebay has some for 10Euro or less (just search for "emu10k"). And yes "PC"-cards will work as these have no x86 or PPC ROM to start with (and even if they had one it would most probraly be ignored by MorphOS).
  • »12.07.12 - 16:07
    redrumloa
    Kronos,
    As long as it is not a Dell pull.
  • »12.07.12 - 16:12
    runequester
    Gotcha. I'll take a peek at the intarwebs and make sure it isn`t a dell
  • »12.07.12 - 16:37
    Simon
    Posts: 809 from 2008/7/6
    I have a spare one. salvaged it from an old pc and tested it in my powermac. But since I already have one it's unused.
  • »13.07.12 - 08:30
    Jeckel
    Posts: 133 from 2007/3/11
    I have one spare too.
    Let me know if you want it.
  • »13.07.12 - 10:09
    runequester
    thanks guys. I got something sorted out I think
  • »13.07.12 - 10:35
    runequester
    okay, the one I got turns out to probably be the wrong chip, so if either of you have one you know works, I'd love to take it. Shoot me an email at runequester@gmail.com and we can sort out details
  • »17.07.12 - 03:58
    bash64
    Posts: 977 from 2010/10/28
    I have one.
    Worked fine.
    Best one made that works with MorphOS.
    My quicksilver motherboard died.
    I also have a video card, and a 5 port usb card.
    All work with Morph.
  • »19.07.12 - 18:06
    runequester
    As an aside is there a difference between emu10k1 and emu10k1-sff?
  • »20.07.12 - 02:39
  • News Moderator
    News Moderator
    Darth_X
    Posts: 571 from 2003/2/10
    I hate to be the guy asking the stupid questions, but why doesn't the Dell edition work?
  • »20.07.12 - 23:36
    runequester
    Unsupported chip from what I can tell.
  • »21.07.12 - 01:40
    redrumloa
    Darth_X,
    Certainly not a stupid question. I lost a couple dollars in my quest for a SB Live due to Dell. The dell part has a chip with that part number but is not compatible.
  • »21.07.12 - 11:00
    Posts: 12566 from 2003/5/22
    I think it's a slightly different part number.
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=8215&forum=11&start=10
  • »21.07.12 - 19:01
