WTB: Powerbook G4 17'' HiRes Logic Board A1139
    CountRaven
    Posts: 566 from 2007/12/10
    Hello folks :)
    Yes I am after the Logic Board of the Powerbook G4 17'' HiRes Model.
    Model Number is: A1139
    Need it for my PowerBook. Please see the machine specs bellow that will help you to understand what machine I have.
    I can paypal a resonable price for it -150 euros / $200 -maximum- incl. postage to Greece.
    Thanks for looking.
    Product Identifiers
    Manufacturer Apple
    Product Family PowerBook G4
    Model ID PowerBook5,9
    Model Number A1139
    MPN M9970LL/A
    UPC 718908094082, 718908446263
    Processor
    Processor Type PowerPC G4
    Processor Speed 1.67 GHz
    Number of Cores Single-Core
    Motherboard
    Bus Speed 167 MHz
    Display
    Display Technology TFT Active Matrix
    Screen Size 17"
    Display Max. Resolution 1680 x 1050
    Technical Features
    Security Features Kensington Lock Slot, Slot For Cable Lock
    Expansion Ports 1 x IEEE 1394a (FireWire), 1 x IEEE 1394b (FireWire), 2 x USB 2.0, DVI (Digital Video Interface), RJ-11 (modem), RJ-45 (NIC), S-Video out, VGA out
    Expandability 1 x Type I/II PC Card Slot
    Hard Drive
    Hard Drive Capacity 120 GB
    Hard Drive Rotation Speed 5400 RPM
    Storage Controller Type IDE, Ultra ATA, Ultra ATA 100
    Memory
    Installed RAM 512 MB
    RAM Technology DDR2 SDRAM
    Max Supported RAM 2 GB
    RAM Speed 333 MHz
    Installed Cache Memory 512 KB
    CD / DVD
    Optical Drive Type DVD±RW/CD-RW
    Optical Drive Read Speed 24x (CD), 8x (DVD)
    Optical Drive Write Speed 2.4x (DVD+R Dual Layer), 24x (CD), 8x (DVD+R), 8x (DVD-R)
    Optical Drive ReWrite Speed 10x (CD-RW), 16x (CD-RW), 4x (DVD+RW), 4x (DVD-RW)
    Video
    Graphic Processor ATI MOBILITY RADEON 9700
    Installed Video Memory 128 MB
    Graphic Bus Interface AGP x4
    Audio
    Audio Output Type Headphones, Line Out, Sound card, Speaker(s)
    Audio Input Type Integrated Microphone, Line In (3.5mm), Microphone, Optical Digital In
    Modem
    Modem Type Fax / Modem
    Analog Modulation Protocol ITU V.92
    Networking
    Networking Type Bluetooth, Integrated Wireless LAN, Network Adapter
    Data Link Protocol AirPort Extreme, Bluetooth, Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g
    Battery
    Battery Run Time 5.5 Hours
    Battery Technology Lithium ion
    Dimensions
    Depth 10.2 in.
    Height 1 in., 1.02 in.
    Width 15.4 in.
    Weight 6.9 lb.
    Miscellaneous
    Release Date October, 2005
    Input Method Keyboard, TouchPad, Trackpad
    Operating System Apple MacOS X 10.3, Apple MacOS X 10.4
  • »01.11.11 - 22:36
    osco
    Posts: 680 from 2009/10/20
    Google the MPN: manufactures part number
    Go to EBAY and search on it.
    There are a few there listed.
    There is a video how to install on the web
     8-)  8-)  8-)  8-)
  • »04.11.11 - 07:09
    CountRaven
    Not so easy for the specific model.
    That is why I am asking for some extra help in here as well.
    In Greece where I live those items are rare as hell.
  • »08.11.11 - 22:26
    CountRaven
    You would come across PBooks but not the HiRes models, for the same reason I have posted a similar topic when I was searching for a PBook.
    I was not so lucky with this - too long story to post it here- but I am not giving up wanting to have my first MorphOS portable machine on time for the 3 release.....
  • »08.11.11 - 22:28
    CountRaven
    And OK I am a little disappointed. I have been reading that you can get Powerbooks for deadly cheap prices. But this is is a myth I guess. Have seen those machines sold for $700 -on used Mac shops-. Have found prices for out of stock Logic boards to be 345 GBP -two random examples-. Have paid 450 GBP for a HiRes PBook -ebay-, found a cheaper one locally -300 euros- so sold the other one to take back some money. Got the second one, on an attempt to open it to do some upgrades I have found that the keyboard connector was almost broken -it was anyway a matter of time for this connector to break I guess, even if I kept the machine closed....-, so I ended up with a totally broken connector. New logic board is the only solution due to a technician on local Mac Service. So I am trying to find a new affordable one or a new cheap PowerBook. Perhaps I do not know where to look but anyone around here can have an opened eye for me. Yeah I know it would be much more difficult to find someone to fix this mobo and perhaps more costly. So I am after a replacement one or a new machine. Would first go for the replacement mobo but a new machine in a reasonable price would probably be an alternative.
    Any kind of help or suggestions especially from those of you who have somehow -any type of- connections to those "low priced" machines -if any- would be great.
    I do not know perhaps they cost much cheaper in France, Germany or Belgium.... -for example-...
    will go on searching as well....
    To find a CSPPC for my 4k back on the day was less pain :)
    [ Edited by CountRaven 09.11.2011 - 02:24 ]
  • »08.11.11 - 23:01
    osco
    :-) http://www.ebay.com/itm/Apple-PowerBook-G4-17-A1139-1-67GHz-Logic-Board-820-1810-A-Tested-/280747495369#shId
    $299.00
    $39.00 shipping to Greece
    [ Edited by osco 08.11.2011 - 21:33 ]
  • »08.11.11 - 23:17
    CountRaven
    ended :(
  • »09.11.11 - 01:40
    osco
    http://myworld.ebay.com/lpfixparts310/?_trksid=p4340.l2559
    http://www.ebay.com/itm/Apple-PowerBook-G4-17-A1139-1-67GHz-Logic-Board-820-1810-A-Tested-/270821750915#ht_870wt_862
    Please contact this seller. Ships to Greece and seems to have many logic boards
    [ Edited by osco 08.11.2011 - 22:04 ]
  • »09.11.11 - 02:00
    CountRaven
    Thanks :) I have also noticed those ended items, but have not contacted the seller, lets try :)
  • »09.11.11 - 02:09
    osco
    http://www.pchub.com/uph/laptop/64-42068-11868/Apple-PowerBook-G4-Aluminum-A1139-1.67GHz-17-Main-Board-Motherboard-.html
    Shipping to Greece too
    Also has the accessories for installation :_
    [ Edited by osco 08.11.2011 - 22:14 ]
  • »09.11.11 - 02:10
    CountRaven
    Yeah I have checked this one as well. They are out of stock. I have placed my email in order to get notified for re-stock. This is a great price. I wish I could find one in this price :)
  • »09.11.11 - 02:13
    osco
    maybe Craigslist in major cities like la ny boston search on powerbook http://boston.craigslist.org/gbs/sys/2690545009.html
    [ Edited by osco 08.11.2011 - 22:20 ]
  • »09.11.11 - 02:17
    CountRaven
    I have contacted this ebay seller first. Lets hope for something cool. Hey thanks for all your time and tips :)
  • »09.11.11 - 02:29
    CountRaven
    I have also found one logic board from UsedMac.inc in US. The total cost is 370 USD including postage. It is way to expensive but if it is my last solution I am going to go for it.
  • »09.11.11 - 02:34
    osco
    http://www.ebay.com/itm/250928764103?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
    Not that far away from me :-o
  • »11.11.11 - 14:41
    Korni
    Posts: 473 from 2006/2/23
    Prices highly depend on place where the hardware is sold. Here (in Poland) you can get easily an used MorphOS compatible PowerBook for around 600 PLN (190 USD). Prices dropped much after Mac OS X 10.7 release - Example. I got myself a powerbook5,6 for 175 PLN (55 USD), with a broken matrix and overally far away from a perfect visual shape. Used 1280x854 matrix costs 100 PLN (30 USD).
    [ Edited by Korni 11.11.2011 - 17:56 ]
  • »11.11.11 - 15:53
    osco
    http://www.ebay.com/itm/Apple-G4-PowerBook-17-320-GB-1-67-GHz-2GB-10-5-8-CS4-DVDRW-DL-WiFi-Apps-/290631820585?pt=Apple_Laptops&hash=item43ab01a529#ht_2472wt_1215
    Top of the line! 8-)
  • »11.11.11 - 23:43
    osco
    http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=260895680758&fromMakeTrack=true&ssPageName=VIP:watchlink:top:en#ht_500wt_1327
    ddr2 memory is a tip off.
    there are two 17"s one an A1085.
    the other? an A1139 !!!!!!!!!!!!!!!!!!!!!!!!!!
    update in your search  :-o  8-)  8-)
    [ Edited by osco 16.11.2011 - 19:50 ]
  • »16.11.11 - 22:56
