Posts: 119 from 2004/8/21
i have a whole peg2 motherboard & CPU if you're interested $400 in the other thread... i know it's not exactly what you asked for, but finding a separate CPU card is probably very difficult - the G4 CPU cards usually die quicker than the motherboards... due to the fans dieing. btw, mine is a G3 600Mhz
