I assume you want this primarily to use under OSX as the drivers for these cards under MorphOS do not support 3D yet.
I haven't tried the 9700 or 9800 under OSX, but I have used a FireGL X3 that has been re-flashed with an X600 XT bios in my 1.8 Ghz Quicksilver.
I have tried Doom3 with that configuration and its more than adequate (the game looks really cool).
You shouldn't have any trouble finding a PC 9700 or 9800 on Ebay within your price range.
Flashing one is not hard. I can relay the sites for the instructions on doing this and where the bios files can be found. Or, if you want, I'll do it for you (Virginia is pretty close to Delaware).
