FS: Pegasos I G3@700 MorphOS Keyfile 768MB April2 complete
    SilkWorm
    Posts: 54 from 2005/4/12
    For sale is a Pegasos I complete system with the following equipment:
    - CPU G3 700 MHz
    - April2 Fix
    - 768 MB RAM
    - Radeon 9100 128 MB graphics card
    - SounbBlaster 5.1 sound card
    - 80 GB hard disk drive
    - DVD-burner (LG)
    - ANTEC Aria cube case
    - Power Supply Unit (ATX) 300W
    - MorphOS 2.x registered (with keyfile)
    [ Edited by SilkWorm 21.07.2011 - 22:03 ]
  • »03.07.10 - 05:57
    stephen_robinson
    Posts: 746 from 2007/4/22
    I've posted intrest on, the other forum...
  • »03.07.10 - 08:39
    SilkWorm
    I've just received your payment.
  • »03.07.10 - 09:52
    magnetic
    Posts: 2129 from 2003/3/1
    spider
    how did you get the board to 700mhz???
  • »03.07.10 - 20:28
    SilkWorm
    magnetic wrote:
    spider
    I've just followed instructions on this site:
    http://www.pegasoswiki.de/index.php/Pegasos:Prozessortuning_G3
    with only two exceptions:
    1. Pegasos I bus freq is 100 MHz, so setting multiplier to 7 (only one "jumper" is closed) means 700 MHz, not 931 MHz like in table on the site above.
    2. After removing the resistors, I've replaced the needed one with a drop of solder.
  • »04.07.10 - 11:42
    stephen_robinson
    I did wonder why it had a fan, I thought the standard speed was 700!
    Did they ever sort out transferring ownership/changing the name of the registeree? It's not that vital to me to be honest, but it'd be nice to know.
  • »04.07.10 - 18:22
    Posts: 2730 from 2003/2/24
    The MorphOS key is bound to the hardware...
  • »04.07.10 - 22:46
    stephen_robinson
    Did they ever sort out transferring ownership/changing the name of the registerer owner?
  • »05.07.10 - 03:56
    Crumb
    Posts: 737 from 2003/2/24
    @lord spider
    I thought there were some problems overclocking Peg1 and for some strange reason I thought it was limited to 666Mhz. Do you know if it could be overclocked to 800Mhz fitting a good heatsink and fan?
  • »05.07.10 - 11:40
    SilkWorm
    I never needed to transfer the name of the original license buyer, so I don't know if MOS Team will do it.
  • »05.07.10 - 16:05
    SilkWorm
    My board did not boot up with multiplier greater than 7.
  • »05.07.10 - 16:06
