FOR SALE: Efika with 4GB CF card.
    Hell_Labs
    Posts: 15 from 2010/1/22
    Efika, 4gbCF card, picoPSU, silver case and power cable. Morhpos installed. Hardware works fine, Cames with a licence key that no longer works due to dead battery. ?70 or a good offer plus postage cost.
    [ Edited by Hell_Labs on 2010/3/1 21:48 ]
    More info:
    The case is a modified one of these:
    http://www.amazon.co.uk/MY-Link-5-25-Enclosure-case-CD-ROM/dp/B000MFNC6C/ref=sr_1_2?ie=UTF8&s=electronics&qid=1267804937&sr=8-2
    [ Edited by Hell_Labs on 2010/3/5 15:48 ]
  • »18.02.10 - 16:00
    Posts: 1383 from 2010/1/6
    I've got a similar problem after changeing battery - the MAC was corrupted so that the MOS-keyfile would'nt work......
    If you turn off EFIKA for 5 mins and turn it on WITHOUT the battery in place, the correct MAC should establish. If it does you can replace the battery during EFIKA is running......- if not try again! (thank Geit for this hint)
    Btw: The origin MAC is (should be?) hardwarecoded and not stored in any backup-RAM. AFAIK there is only a possibility to set a 2nd, in the last 4 bytes different MAC only for the actually running session....I've read about this in a Freescale OF manual, but I don't know how one could activate this on EFIKA - I've tried this with "set-env local-mac-address xxxx" (only the last 4 bytes are changeable) - but it doesn't take effect on EFIKA.......(although the EFIKA-SF knows this command.....)
    Maybe this will help you to get "this piece junk" running.........
    [ Editiert durch Amigaharry2 an 2010/2/18 20:13 ]
  • »18.02.10 - 18:10
    Hell_Labs
    I'll try again then.
    But I still want to sell it, I'm buying a laptop.
  • »18.02.10 - 19:25
    trotter
    Posts: 106 from 2010/1/14
    Where in the NW are you I am in bolton.
    Surprised to see someone relatively near me.
    Dont want to buy it just wondering.
    Martin
    Running MorphOS v3.18 on Mac mini 1.5GHz 64meg VRAM,1gig ram.
    Palm T3 pda along with pixel 4a GrapheneOS smartphone. Updated August 2023
  • »18.02.10 - 21:46
    stephen_robinson
    Posts: 746 from 2007/4/22
    I live in the Northwest, I'm was thinking of putting my licensed Efika on ebay this weekend, the battery's keeps being eaten, but at least the registration/mac address is kept.
    Efika was ok, but in the days of Mac minis the lack of memory was simply the killer for me, when you can't play a game as old as Hexen II because the memory been filled up... :(
  • »18.02.10 - 22:00
    Hell_Labs
    St.helens.
  • »18.02.10 - 22:10
    The EFIKA-concept provides a very small industrial board (like a thin client) i.g. for small server applications, coding, POI-applications, etc......but not really for games.....! In this case it seems to be better for you to sell EFIKA and buy a PegasosII or MacMini.......you will have much more fun with MOS......  :-D
    [ Editiert durch Amigaharry2 an 2010/2/19 6:34 ]
  • »19.02.10 - 04:34
    trotter
    Ahh right wigan ish way
    Martin
  • »19.02.10 - 18:01
    Hell_Labs
    Eww dirty wiganers.
    I've had an offer, I'll have a go with the keyfile again tommorow then its going to sadddam, unless someone else makes an offer. I'd just like to say that trading for a PowerBook G3 would be cool too.
    [ Edited by Hell_Labs on 2010/2/19 21:32 ]
    [ Edited by Hell_Labs on 2010/2/19 21:42 ]
  • »19.02.10 - 19:31
    Hell_Labs
    Bump. Still for sale because of difficulty contacting the user Saddam. Price fixed.
  • »01.03.10 - 19:50
    DrZarkov
    Posts: 142 from 2004/3/21
    Haven't you got my PM?
  • »03.03.10 - 16:35
    Hell_Labs
    Whoops! I forgot to check here, I wasn't expecting to get any attention! DrZarkov check your inbox now  :-)
    Almost sold to DrZarkov.
    [ Edited by Hell_Labs on 2010/3/6 20:16 ]
  • »05.03.10 - 13:47
    DrZarkov
    I've got the Efika, but I need to contact Hell_Labs. Does anybody have an e-mail adress, as he obviously does not read here any more or controls his PMs...
    Maybe he is active in any other forum?
  • »24.03.10 - 08:40
    gaz_god
    Posts: 15 from 2006/4/17
    @DrZarkov
    You could try amiga.org, he's quite active on there.
    Gaz
    http://www.lincsamiga.org.uk
  • »24.03.10 - 12:51
    DrZarkov
    The Efika is up and running again! The registration problem is solved, it worked after a) changing the battery and b) a clean reinstallation of MorphOS. And I've replaced the power-connector with a more solid solution. Now I'm looking for a 12" or 13" monitor with the highest possible (at least 1024x768) resolution.
  • »12.04.10 - 11:01
    Ruud
    Posts: 335 from 2009/2/2
    Glad to read you've got it sorted :)
    Looks like it's in good hands now after its mis-adventures with Hell_Labs ;)
    I sold it to him for a bargain price but I think maybe you got an even bigger bargain buying it from him!
  • »12.04.10 - 17:50
    DrZarkov
    I hope so, it is my third machine running MorphOS (serial, not parallel). I would like a smaller laptop than my old Pegasos I laptop I've made some years ago for Senex. (http://www.retrocom.de/pegasos.html)
  • »13.04.10 - 16:17
    kickstart
    Posts: 227 from 2009/4/28
    Nice work.
  • »13.04.10 - 16:33
