JKD wrote:
I assume USB hdd.class is supported?
250GB Lacie drive sold to amigadave
I still have the larger sized 500GB. It's a 'mini-hub' device and matches the Mac Mini cosmetics perfectly!
Yep! USB connection works fine, but not when the Firewire is connected, you can't have both Firewire and USB connected at the same time. It is a very nice looking external hard drive enclosure that matches the MacMini perfectly. Anyone wanting more hard drive space for running both MorphOS and MacOSX, this is a nice way to go. It also gives you an additional USB port by using one USB port to connect and having 2 USB port hub built-in.
