Posts: 12557 from 2003/5/22
> The 3D examples obviously aren't working
Okay. So the Radeon 9800 works in 2D mode only. That's good to know because I always thought that OS4 doesn't support Radeons greater than 9250 at all, not even in 2D. Now the listing of the 9800 as OS4 compatible on
IntuitionBase and
ACube Website makes sense to me :-)
> I've just downloaded the minigl libraries and installed it (which means copying
> them to the libs directory).
That should suffice.
