FS: Power Mac G5 Dual 2,7 GHz
    Posts: 1362 from 2004/2/8
    I have a Power Mac G5 for sale.
    The specs are:
    - Two PPC970fx (G5) CPUs at 2,7 GHz (water cooled)
    - 8 GB of DDR RAM (PC3200)
    - ATi Radeon X1950 (AGP) - PC version (working with MorphOS, but no Apple BIOS inside so no OSX or Open Firmware available)
    - 250 GB SATA hard drive
    - standard optical drive for this model (aka the "SuperDrive")
    - AirPort and Bluetooth (both with external antennae - seen on photos)
    - An additional 4-port USB 2.0 card (NEC chipset)
    I've also installed a 56k modem board, just for the sake of completeness (as this model doesn't have it by default and even lacks the proper backplate wires AFAIR)
    The water cooling has been refurbished when I got it. Lately it's been refilled and checked for any signs of leak.
    The PowerMac has got MorphOS 3.15 installed and registered.
    One more thing: I've demounted the plastic "deflector" as it collided with Radeon X1950 (the card is quite wide). It will be included with the machine ofc. I might also add an OSX/Open Firmware compatible gfx card (I should have at least one nVidia FX5200 here. If I can find a flashed Radeon 9200 I will include it too).
    You can see some photos here. The "G5" cover is there too, it's just been demounted for the purpose of CPU module inspection.
    I'm asking for 180 EUR plus the shipping cost.
  • »03.01.22 - 04:59
    Daff
    Posts: 251 from 2003/4/5
    Intereted.
    Please contact me on "obligement AT free.fr"
    http://obligement.free.fr
  • »03.01.22 - 05:34
    BatteMan
    Posts: 294 from 2003/2/24
    Interested too (in second row ^^).
  • »03.01.22 - 08:26
    BatteMan
    Received it yesterday and I want to say thank you to Koszer ! Very well package and fast delivery. The computer is in very well condition for his age and it's working perfectly !
    So a good transaction with a great seller ! Thx.
  • »20.01.22 - 16:33
    Newcgen
    Posts: 10 from 2022/4/11
    The specs are:
    Hi!
    I have a Power Mac G5 and an AGP X1950 pro.
    How can I connect external power to the X1950 pro?
  • »11.04.22 - 16:10
    My X1950 got two Molex ports. Just in case I powered it from two different wires.
    I got the first one splitting the Molex from the DVD drive, and a second one - routing a SATA power to Molex cable from the hard drive bay.
  • »11.04.22 - 16:45
    Newcgen
    Thanks, but my MorphOS won't boot :-(.
  • »20.04.22 - 16:57
    Are you sure your Radeon is OK?
    I had a Sapphire one (like this).
    Also it's worth mentioning that some cards (like the one I got) is too wide to fit in G5 together with plastic deflector. If you force the deflector in, the card bends downwards and may fail (or cause a short and burn some power cable - that happened to me).
  • »25.04.22 - 05:30
    Newcgen
    I have the same video card. It works with PC.
    MorphOS boots with the original Radeon.
    The boot-device env is sd1:,\\bootinfo.txt
  • »30.04.22 - 03:54
    Then I have no idea why it wouldn't work for you.
    Let's sum it up:
    1. You're booting from a hard drive with MorphOS pre-installed, right? Not from CD live image (trying that will surely fail)?
    2. Both Molex power connectors are connected?
    3. The plastic deflector is out?
  • »30.04.22 - 09:22
    Newcgen
    Let's sum it up:
    Absolutely right.
    The fan roars, but nothing happens. As if OF does not start.
  • »30.04.22 - 14:41
    Correct, the Open Firmware wouldn't start without Mac-compatible gfx card. But MorphOS boots nevertheless. Still nothing if you leave it for a while? Does the main fan go full swing or does it operate normally?
  • »01.05.22 - 04:01
    Newcgen
    After 3 minutes the main fan go full swing. The caps lock key does not work.
  • »04.05.22 - 06:04
    And MorphOS is working normally on the same computer but with another gfx card?
  • »04.05.22 - 09:07
    Newcgen
    Just replacing gfx card(original from Apple) makes MorphOS normally working.
  • »04.05.22 - 10:04
    Then my best bet would be that either the gfx card doesn't get enough power to operate, or that it's some kind of unsupported revision (I have a PCIe X1950 that runs just fine with PC motherboard but refuses to initialize when in Power Mac QUAD with MorphOS).
  • »05.05.22 - 03:13
    Newcgen
    Could you show the output of your printenv command?
  • »19.05.22 - 04:54
    You mean - the printenv command on a Power Mac G5 Dual Processor 2,7 GHz with Sapphire Radeon X1950 that I don't own anymore (post #4, Batteman confirms he got the machine in January)?
  • »19.05.22 - 05:08
    Newcgen
    Of course you don't have it anymore. I forgot :-).
  • »19.05.22 - 10:59
    BatteMan
    We don't have access to openfirmware with a non mac gfx card, so we don't have access to printenv...
    Sorry...
  • »19.05.22 - 19:20
