[SOLD]: PowerMac G4 MDD (1,25 GHz)
    Posts: 1362 from 2004/2/8
    I have a PowerMac G4 MDD for sale. Specs:
    - A PowerPC 7455 (G4) CPU at 1,25 GHz
    - 2 GB PC2700 DDR RAM
    - ATi Radeon 9000 Pro (64 MB VRAM) gfx card
    - 80 GB hard drive
    - 12x "Combo" (DVD-ROM/CD-RW) optical drive
    - MorphOS 3.12 (unregistered) installed. I can also install OSX 10.5.8 in dual-boot.
    The price is 40 EUR plus shipping.
    Some photos here.
    EDIT: The machine has been SOLD. Thanks.
    [ Edited by koszer 09.02.2020 - 18:37 ]
  • »30.01.20 - 15:38
    - 80 GB hard drive
    Some photos here.
    Is that the single 1.25GHz G4 CPU module, or is it the dual 1.25GHz G4 CPU module?
    IMHO, that is one of the best MorphOS systems, and easiest to work on. Easily able to over-clock to 1.5GHz, or higher, but I think that 1.5GHz is the safer clock speed for that G4 CPU.
  • »30.01.20 - 17:30
    Posts: 12565 from 2003/5/22
    >> Some photos here.
    > Is that the single [...] CPU module, or is it the dual [...] CPU module?
    Single according to the label in the 4th photo.
  • »31.01.20 - 07:49
    Brumiga
    Posts: 277 from 2004/4/3
    @koszer,
    A very big question... How are the fans of the power supply ? Loudy or not ? Or has the stock power supply, with loud fans, been exchanged by apple as warranty during the period it was sold for an other one wth more quiet fans ? The one I had during 4 years was with a stock power supply and the fans very loudy.
    Brumiga
  • »31.01.20 - 11:51
    Brumiga wrote:
    @koszer,
    A very big question... How are the fans of the power supply? Loudy or no ? Or has the stock power supply, with loud fans, been exchanged by apple as warranty during the period it was sold for an other one wth more quiet fans?
    The computer is reasonably quiet, no infamous "wind tunnel effect" known from earlier G4 PowerMacs. I'd say it's quieter than my LCS G5 (of course the G5 has got an actively cooled GPU, not a passive Radeon 9000 like this one). I'll take a look at the vendor of the PSU as soon as I'm back home but I believe that (as it's a last production batch unit) the problems have been solved in the manufacturing plant for these. I'll also perform some stress tests to check how loud it can get.
  • »31.01.20 - 13:55
    Posts: 19 from 2019/12/31
    In my MDD i changed fan to AAB Cooling Silent JET Fan 12 PWM and in PSU two FANDER ROXO 6025H 60MM FRX3-6025H , and this configuration works with overclocked 1.33 to 1.58 single CPU.
    it is much quieter than stock config.
  • »02.02.20 - 13:35
    Machine sold.
  • »09.02.20 - 16:37
