Posts: 1087 from 2003/3/24
I am selling my beloved PowerBook G4 17"
The Display was replaced with a MacBook Pro 17" Display with 1920x1200 resolution instead 1680x1050 pixels.
The PowerBook has an IDE2SATA Adapter so you can put every 2,5" HDD or SSD inside.
The Battery is in an ok shape an has around 3000mAh from 5400mAh when it`s fully loaded.
Maybe it can be trained to more.
MorphOS 3.11 and OS X 10.5.8 are per installed. I sell this machine with a key for MorphOS.
The Keyboard and the Touchpad are in great shape.
But the PowerBook has some scratches and dents all around.
Beside that everything is working.
Specs are:
- a PowerPC 7447A CPU at 1,67 GHz
- 2 GB of DDR2 RAM both RAM-Sockets are working
- FullHD+ display at 1920x1200 resolution instead of standard 1680x1050
- Radeon Mobility 9700 with 128 MB of VRAM
- "SuperDrive" optical drive
- 512 GB hard drive
- AirPort and Bluetooth built in
- German keyboard layout
- genuine 65W power adapter included
The Price is 180 Euro, plus shipping.
[img=https://abload.de/thumb/pb17vjgf.jpg]
[img=https://abload.de/thumb/pb2y5jgm.jpg][img=https://abload.de/thumb/pb3tej24.jpg]
[img=https://abload.de/thumb/pb4iwkbw.jpg][img=https://abload.de/thumb/pb5lcj56.jpg]
[img=https://abload.de/thumb/pb6bakm1.jpg] [ Editiert durch ThePlayer 20.11.2019 - 09:18 ]PowerMac G5 Quad 2.5 running UWQHD Resolution
