Posts: 2095 from 2003/6/4
DFergFLA schrieb:
Cancel that Acill, all is good.. well at least getting better. Do you have any problems with the wireless in on your new laptop? Mine is giving me fits, but only under MorphOS.
Before I got my new Fritzbox as router I sometimes had issues to get connected to the net (used a repeater in my WLAN). Since that is retired and the new Fritzbox at a proment place in the house does the entire job, it's fine. But the Airport. signal under MorphOS is rather weak. Hence. I still use the Atheros pcmcia card. Provides a better throughput.
