FS: 1.42 GHz iBook
    Posts: 1385 from 2010/1/6
    First: right User and Password?
    Second:
    There may be a similar problem, I had with Pirelli-router: When I tried to login nothing happens.....but then I've seen that the content of URL-Line in OWB has changed. Here I deleted the last entry, pressed Enter and it works!
    eg:. in my case:
    1. after first attempt to login URL shows: http://10.0.0.138/ui/login
    2. deleted 'login' and pressed Enter
  • »16.11.13 - 12:39
    Yasu
    Posts: 1724 from 2012/3/22
    User and password is correct. I have used this wifi for years. It works with AROS etc.
    I will take a look at suggestion #2.
    My MorphOS blog
  • »16.11.13 - 13:20
    Yasu
    Ok, I found where I had done wrong. I had to directly put in the correct name and password in the quick setup and patiently wait for the router to accept the input (takes about 30 seconds to 1 minut). Up until now I have tried to connect directly via WiFi without any success. At least the WiFi part shows what settings all surrounding WiFi's are using so I don't have to guess.
    And it's pretty fast too :-)
    My MorphOS blog
  • »19.11.13 - 22:44
