ezTCP - try #2
    Posts: 408 from 2004/7/15
    I've uploaded the second release. Unfortunately not everything is fixed, several original problems were discovered, but there is a chance that DNS works now. Please report.
    2 micky060: Yes, strange. Try running a kernel from the command prompt, i think it tells you about some error there. Startnet just sends the output to NIL:
    Next fixes are expected on monday or tuesday, sorry, saturday is my wife's birthday, i need to do some preparations at home...
    iPod, iBook, iMac,... iRobot?
  • »15.09.05 - 04:17
    Miky060
    Posts: 694 from 2003/2/24
    Hi Sonic, yesterday I reached to solve the problem (thx scf), editing the solv.conf file.. ezTCP went online! :-) Obiosuly without DNS is few usable.
    Now I would like to try the 0.2. Where is it? I can'it find the link.
    Thx.
  • »15.09.05 - 05:49
    Posts: 916 from 2004/1/24
    You can find ezTCP v0.2 under the original link (as of now ;-) )
  • »15.09.05 - 05:52
    weiseb
    Posts: 212 from 2003/3/29
    I am online with it :)
    But dns still does not work for me
    everything resolves to 64.49.213.239
    @micky060
    when do you get the error? Maybe its because
    the version of bsdsocket.library is 3.x and not 4.x.
    If you just want to surf the web without dns use a proxy (you have to use its IP for the settings of course)
    [ Edited by weiseb on 2005/9/15 11:02 ]
  • »15.09.05 - 08:00
    Posts: 261 from 2003/3/13
    What better birthday gift then a MOS native
    TCPIP stack with DHCP enabled ???! :P
    Gr,
    Felix.
  • »15.09.05 - 08:41
    We are already investigated the new DNS issue. The workaround is to remove (or comment out) all DOMAIN entries in the resolv.conf. Antibike discovered this effect. :idea: It will be definitely fixed soon, now i exactly know where to look for the bug.
  • »15.09.05 - 08:44
    Crumb
    Posts: 736 from 2003/2/24
    @Sonic
    it's great to read your progress reports here. lots of thanks :-)
  • »15.09.05 - 12:51
    Mi-Go
    Posts: 95 from 2003/9/18
    thanks for the effort!
    Now I'm sufing with it. :-D
    everyting's quite fast, except for morphzone...
  • »15.09.05 - 13:21
    There were requests to bump bsdsocket.library version to v4. I've studied Miami's and AmiTCP's SDKs and there is only one thing added - socket events.
    v0.3's bsdsocket will have v4 then. It will report "Function not implemented" on this function call in order to avoid crashes. Also it will report on unknown SocketBaseTags and unknown IOCTLs. This will help to figure out what software need what.
    Also i expect to clean up known bugs list at all.
  • »16.09.05 - 03:44
    SoundSquare
    Posts: 1214 from 2004/12/1
    it sounds so easy with you Sonic. Once this TCP/IP stack will be done, why not joining the amizilla team to speed up the whole stuff ?;-) hehe
  • »16.09.05 - 04:27
    Heh, may be... Or start something new like Firewire... BTW, anyone knows what is the status of AmiWire/MorphWire by DiscreetFX?
  • »16.09.05 - 05:13
    After some testing here is new, re-summarized buglist:
    1. Samba doesn't work - will be investigated, not really clear problem
    2. Applications utilizing file (socket) descriptor creation callback will crash because calling conventions are wrong - found, will be fixed.
    3. Resolving via DNS works only if no DOMAIN lines are specified in the resolv.conf - will be investigated, unclear, but probably closely relates to (1) - netdb gets screwed up in memory.
    4. Wrong Ctrl-C handling in the DNS resolver (see download description for details) - found, will be fixed.
    5. Ping tool can leave bsdsocket.library opened preventing ezTCP from quitting - found, will be fixed.
    6. bsdsocket.library has version number 3 so there are non-working applications which ask for v4 - will be updated to 4, but new features will not be implemented, errors will be generated if some application will attempt to use them and warnings will be printed in the log; so some applications will continue not to work.
  • »16.09.05 - 08:05
    SoundSquare
    no idea but it should be quite easy to contact them.
  • »16.09.05 - 08:30
    Posts: 1932 from 2003/10/19
    Sonic: Great work again, your moving along at a great speed. I would think in two months you will have a fine application to give everyone.
    About firewire, I've looked into it a lot and from what I have found its not an open standard. The stuff in linux isnt that great and is more or less hacks. The real SDK and docs you need cost a lot of money to get.
  • »16.09.05 - 11:08
  • Targhan
    Posts: 2833 from 2003/2/7
    Some info...
    DevTracker Page: https://morph.zone/modules/devtracker/index.php?proj_id=2
    @Acill - Check that you have admin rights for the devtracker. If you don't know how to project manage, then you get OJT :-P
    @Sonic - due to a bug in the current version of the devtracker, please use the date as the version number. The thing isn't accepting periods or non-numeric characters. So maybe something like DDMMYY would be best for version numbers in that thing. (even though the release can be V.02.b12 or whatever).
    @users - when submitting a bug, you should be able to attach text files (i.e., logs); however, I've yet to test this feature.
    Happy Testing!
    (and beware the server will be down sometime this weekend to double the processing speed on the server...)
    :idea:Targhan
  • »16.09.05 - 14:39
    Motosampy
    Posts: 199 from 2004/8/14
    This is great !
    After short testing I'd say the speed difference to Genesis is significant and browsing already works fine, ftp with ATC works fine, Jabberwocky can't connect yet (but it tries, which didn't happen with 0.1).... i know already I'm gonna love version 0.3
    And MLDonkey seems to work fine, it hangs all network action always with Genesis at some point.
  • »16.09.05 - 15:05
    Posts: 2728 from 2003/2/24
    @Acill
    How much is "a lot of money"?
  • »17.09.05 - 06:17
    takemehomegrandma wrote:
    @Acill
    It looks like apple has put out all the info you need to make a stack and drivers for free now. This isnt for Macs, its for any consumer device. I made another thread with links in it to download the stack sources and they are well documented. Its well worth the try.
    Get it here: http://developer.apple.com/devicedrivers/firewire/index.html
    [ Edited by Acill on 2005/9/17 7:16 ]
  • »17.09.05 - 12:00
    zephar123
    Posts: 139 from 2004/3/8
    excellent installation instructions, I know that might soudn dumb, but to many files out there that are impossible to figure out how to install.
  • »17.09.05 - 14:46
    catohagen
    Posts: 297 from 2003/5/20
    doesnt work here either, not unexpected considering its
    a quick and dirty port of acident software.
  • »17.09.05 - 16:22
    amiades
    Posts: 231 from 2005/6/2
    Great work! keep it up.
    I tried to make some pings and everything went well, after that, I tried ibrowse, and I could open a pair of webs using their IP. When I tried to resolve an adress, It didn't work, and after come time, MOS got hung.
    It seemed to be fastest as miami is, but couldn't make a clear test. My congratulations!.
  • »17.09.05 - 17:52
    Its a first release to show what can be done. Its far from final code. Just wait the two months and see where its at then.
  • »17.09.05 - 18:58
    analogkid
    Posts: 713 from 2004/11/3
    V0.2 works for me in IBrowse, YAM and AmIRC. MLDonkey, Jabberwocky and ATC don't work.
  • »17.09.05 - 19:00
    Posts: 108 from 2005/4/3
    Hi all,
    Contributed $165 for ezTCP friday, 16 september 2005 ! Altough, i
    don't see myself listed in the bounty donors section yet, and the
    ezTCP bounty total isn't updated sofar. I'am planning to contribute
    more times.
    Grts, Amigaharry alias Tom Duin
    Visit my Amiga/Pegasos homepage at:
    http://www.angelfire.com/amiga/ex
  • »17.09.05 - 19:49
