I've given up ezTCP bounty
    Posts: 408 from 2004/7/15
    I am looking at it and slowly turning back to MorphOS... I need something...
    $800 is a reasonable sum to try to win. I would like to try it out. My conditions are:
    1. It will be a port or AROSTCP
    2. Upon completion the code will be put into unmorphos CVS for further development.
    3. In case of refusal the code will be put onto CVS anyway.
    In a week i'll try to look at current state of AROSTCP and start compiling it. After this probably i'll officially pick up the bounty.
    I'd like to ask if i am still good enough for you to beleive me (yes, i really have many dropped projects) and if you will let me to accept the bounty.
    iPod, iBook, iMac,... iRobot?
  • »31.08.05 - 07:44
    Wishmaster
    Posts: 342 from 2003/6/29
    Porting from AROS should not be too big a deal.
    I would like to see the khtml project supported.
    Pegasos PPC
  • »31.08.05 - 10:10
