JIT JS Bounty - update
    bigfoot
    Posts: 508 from 2003/4/11
    It's been a bit more than a month since I last posted, and obviously my last prediction didn't come true. The remaining 1.24/1.25 bugs were quite a bit tougher to debug than I had expected, but we're getting closer, and it's ready for the first round of public testing.
    First the caveats:
    1) This still only has the first level JIT enabled, as the second level still needs some debug work. The first level of JIT is not super fast compared to the non-JIT version, so it won't feel super snappy compared to before. Don't expect miracles.
    2) Some things might still be broken. If you discover things that don't work with the JIT version, but do work with the non-JIT version, please let me know. Let me just emphasise that I can't do anything about things that also don't work with the non-JIT version right now, so I'm only looking for reports of things that work with the non-JIT version but don't with the JIT version.
    3) You need OWB 1.25 (from MorphOS 3.11) already installed. Extract the archive in your OWB directory, and then run OWB-JIT to test the JIT version.
    And then the link: https://bigfoot.morphos-team.net/test/OWB-JIT.lha
    I'm not done working on this, and there will be more updates in the future, hopefully with the second level JIT enabled as well at the very least. However, I will be unable to do any work on OWB for the next 3-4 weeks, so any further updates will happen in the second half of August at the earliest.
    [ Edited by bigfoot 18.07.2018 - 13:35 ]
  • »18.07.18 - 11:47
    Posts: 1246 from 2004/2/8
    Awesome news, Thanks Bigfoot! I can't wait to try this at home (unfortunately I'll have to wait about 9 hours, darn).
  • »18.07.18 - 12:22
    bigfoot
    As I mentioned, please don't expect miracles :)
  • »18.07.18 - 12:36
    No kidding. First miracle is that it's ready (well, sort of, I know). And still more miracles to come! This is going to be a good year for MorphOS, that's for sure.
  • »18.07.18 - 13:01
    bigfoot
    Haha, I meant speed wise :) The first level of JIT is quite naive in its approach, so it's not very fast, and Javascript is only a part of the browsing experience.
  • »18.07.18 - 13:09
    Posts: 888 from 2004/1/24
    \o/
  • »18.07.18 - 14:28
    zukow
    Posts: 642 from 2005/2/9
    Seems to be stable. Some things are slower, some faster:
    JIT VERSION:
    RESULTS (means and 95% confidence intervals)
    Total: 3523.1ms +/- 1.6%
    3d: 462.2ms +/- 5.0%
    cube: 111.8ms +/- 5.1%
    morph: 120.8ms +/- 5.2%
    raytrace: 229.6ms +/- 5.5%
    access: 666.0ms +/- 4.6%
    binary-trees: 47.8ms +/- 5.7%
    fannkuch: 331.7ms +/- 8.2%
    nbody: 272.9ms +/- 2.3%
    nsieve: 13.6ms +/- 4.4%
    bitops: 284.5ms +/- 2.4%
    3bit-bits-in-byte: 23.9ms +/- 4.1%
    bits-in-byte: 33.2ms +/- 3.5%
    bitwise-and: 43.3ms +/- 12.3%
    nsieve-bits: 184.1ms +/- 0.5%
    controlflow: 14.1ms +/- 4.4%
    recursive: 14.1ms +/- 4.4%
    crypto: 196.9ms +/- 0.8%
    aes: 116.4ms +/- 0.9%
    md5: 43.8ms +/- 1.3%
    sha1: 36.7ms +/- 2.1%
    date: 260.2ms +/- 0.5%
    format-tofte: 121.6ms +/- 0.5%
    format-xparb: 138.6ms +/- 0.7%
    math: 226.9ms +/- 0.8%
    cordic: 61.7ms +/- 2.0%
    partial-sums: 100.6ms +/- 1.3%
    spectral-norm: 64.6ms +/- 1.5%
    regexp: 655.3ms +/- 0.1%
    dna: 655.3ms +/- 0.1%
    string: 757.0ms +/- 1.6%
    base64: 86.6ms +/- 0.8%
    fasta: 137.3ms +/- 0.6%
    tagcloud: 183.6ms +/- 5.8%
    unpack-code: 264.6ms +/- 0.2%
    validate-input: 84.9ms +/- 1.2%
    NORMAL VERSION
    Total: 3092.4ms +/- 0.3%
    3d: 302.2ms +/- 0.7%
    cube: 85.8ms +/- 1.1%
    morph: 108.3ms +/- 1.8%
    raytrace: 108.1ms +/- 1.2%
    access: 371.6ms +/- 3.0%
    binary-trees: 34.4ms +/- 1.8%
    fannkuch: 191.9ms +/- 6.1%
    nbody: 106.7ms +/- 0.3%
    nsieve: 38.6ms +/- 1.0%
    bitops: 416.4ms +/- 1.2%
    3bit-bits-in-byte: 65.8ms +/- 7.5%
    bits-in-byte: 79.0ms +/- 0.6%
    bitwise-and: 132.4ms +/- 0.4%
    nsieve-bits: 139.2ms +/- 0.4%
    controlflow: 31.5ms +/- 1.2%
    recursive: 31.5ms +/- 1.2%
    crypto: 166.9ms +/- 1.6%
    aes: 79.6ms +/- 1.2%
    md5: 45.5ms +/- 2.9%
    sha1: 41.8ms +/- 1.9%
    date: 189.8ms +/- 0.8%
    format-tofte: 84.0ms +/- 1.2%
    format-xparb: 105.8ms +/- 0.7%
    math: 309.8ms +/- 0.4%
    cordic: 137.1ms +/- 0.4%
    partial-sums: 103.1ms +/- 0.9%
    spectral-norm: 69.6ms +/- 1.3%
    regexp: 686.3ms +/- 0.2%
    dna: 686.3ms +/- 0.2%
    string: 617.9ms +/- 0.4%
    base64: 82.4ms +/- 1.1%
    fasta: 114.6ms +/- 1.5%
    tagcloud: 138.3ms +/- 0.6%
    unpack-code: 210.4ms +/- 0.7%
    validate-input: 72.2ms +/- 1.5%
    [ Edited by zukow 18.07.2018 - 17:38 ]
  • »18.07.18 - 16:32
  • ASiegel
    Posts: 1370 from 2003/2/15
    @ zukow
    Not all applications are suitable for JIT compilation, of course. Things like Mandelbrot fractal generators work quite well already, though. The JIT gives a huge boost for these type of applications (up to 3x speed up in my tests).
    As for your results specifically, I have literally seen bigger differences between subsequent benchmark runs using the exact same browser version and Javascript interpreter.
  • »18.07.18 - 16:46
    bigfoot
    The linked archive has been updated with a new version that re-enables an optimisation that had accidentally been disabled in the previous release.
  • »19.07.18 - 10:46
    Akhem...
    Forbidden
    You don't have permission to access /test/OWB-JIT.lha on this server.
    Apache Server at bigfoot.morphos-team.net Port 443
  • »19.07.18 - 11:53
    bigfoot
    Fixed, thanks :)
  • »19.07.18 - 11:56
    bigfoot wrote:
    Fixed, thanks :)
    It's faster. Tested on 1,33 GHz iBook G4 and it did the Sunspider test in 4203 ms (vs 4754,3 without JIT). More benchmarks to come.
  • »19.07.18 - 14:29
    Spectre660
    Posts: 275 from 2015/6/30
    Just for reference what version of Sunspider ?
  • »19.07.18 - 16:33
    1.0.2
  • »19.07.18 - 16:54
    Spectre660
    Thanks.
    Will Post some X5000/020 Linux PPC results for baseline comparisons .
  • »19.07.18 - 16:59
    Spectre660
    Qupzilla
    Total: 3180.7ms +/- 0.3%
    3d: 300.0ms +/- 0.5%
    cube: 84.1ms +/- 0.3%
    morph: 109.6ms +/- 0.5%
    raytrace: 106.3ms +/- 1.4%
    access: 354.0ms +/- 0.2%
    binary-trees: 41.0ms +/- 0.8%
    fannkuch: 180.3ms +/- 0.3%
    nbody: 89.0ms +/- 0.4%
    nsieve: 43.7ms +/- 0.8%
    bitops: 557.1ms +/- 1.4%
    3bit-bits-in-byte: 74.3ms +/- 6.0%
    bits-in-byte: 95.8ms +/- 1.6%
    bitwise-and: 222.5ms +/- 1.1%
    nsieve-bits: 164.5ms +/- 0.3%
    controlflow: 58.0ms +/- 0.0%
    recursive: 58.0ms +/- 0.0%
    crypto: 192.9ms +/- 0.7%
    aes: 74.8ms +/- 0.9%
    md5: 60.7ms +/- 1.0%
    sha1: 57.4ms +/- 0.9%
    date: 185.3ms +/- 1.0%
    format-tofte: 88.6ms +/- 0.8%
    format-xparb: 96.7ms +/- 1.6%
    math: 378.2ms +/- 0.4%
    cordic: 144.9ms +/- 0.8%
    partial-sums: 150.2ms +/- 0.4%
    spectral-norm: 83.1ms +/- 0.3%
    regexp: 584.7ms +/- 0.2%
    dna: 584.7ms +/- 0.2%
    string: 570.5ms +/- 0.4%
    base64: 88.4ms +/- 2.1%
    fasta: 135.6ms +/- 0.5%
    tagcloud: 124.3ms +/- 0.4%
    unpack-code: 147.4ms +/- 0.5%
    validate-input: 74.8ms +/- 0.6%
  • »19.07.18 - 17:03
    Spectre660
    Midori
    Total: 3161.8ms +/- 5.2%
    3d: 356.3ms +/- 0.5%
    cube: 83.4ms +/- 0.9%
    morph: 156.7ms +/- 0.3%
    raytrace: 116.2ms +/- 1.3%
    access: 381.1ms +/- 0.9%
    binary-trees: 43.1ms +/- 0.5%
    fannkuch: 202.1ms +/- 1.7%
    nbody: 88.3ms +/- 0.4%
    nsieve: 47.6ms +/- 0.8%
    bitops: 494.9ms +/- 0.3%
    3bit-bits-in-byte: 82.3ms +/- 0.4%
    bits-in-byte: 104.7ms +/- 0.3%
    bitwise-and: 136.0ms +/- 0.0%
    nsieve-bits: 171.9ms +/- 0.6%
    controlflow: 46.7ms +/- 0.7%
    recursive: 46.7ms +/- 0.7%
    crypto: 187.2ms +/- 0.4%
    aes: 77.1ms +/- 0.3%
    md5: 57.1ms +/- 0.9%
    sha1: 53.0ms +/- 0.0%
    date: 223.6ms +/- 0.8%
    format-tofte: 103.6ms +/- 0.5%
    format-xparb: 120.0ms +/- 1.2%
    math: 264.5ms +/- 61.4%
    cordic: 69.1ms +/- 234.8%
    partial-sums: 117.2ms +/- 0.3%
    spectral-norm: 78.2ms +/- 0.4%
    regexp: 575.2ms +/- 0.2%
    dna: 575.2ms +/- 0.2%
    string: 632.3ms +/- 0.2%
    base64: 98.2ms +/- 0.7%
    fasta: 116.2ms +/- 0.4%
    tagcloud: 139.2ms +/- 0.6%
    unpack-code: 200.4ms +/- 0.4%
    validate-input: 78.3ms +/- 1.4%
  • »19.07.18 - 17:04
    OWB-JIT on PowerMac G5 2,7 GHz:
    Total: 2430.1ms +/- 0.6%
    3d: 280.7ms +/- 2.9%
    cube: 91.1ms +/- 4.3%
    morph: 98.3ms +/- 5.8%
    raytrace: 91.3ms +/- 4.4%
    access: 317.1ms +/- 2.4%
    binary-trees: 12.8ms +/- 2.4%
    fannkuch: 233.5ms +/- 2.7%
    nbody: 52.9ms +/- 2.2%
    nsieve: 17.9ms +/- 14.4%
    bitops: 244.5ms +/- 2.3%
    3bit-bits-in-byte: 21.4ms +/- 6.9%
    bits-in-byte: 28.1ms +/- 4.9%
    bitwise-and: 42.3ms +/- 4.1%
    nsieve-bits: 152.7ms +/- 3.3%
    controlflow: 12.3ms +/- 18.6%
    recursive: 12.3ms +/- 18.6%
    crypto: 153.8ms +/- 2.1%
    aes: 90.5ms +/- 1.2%
    md5: 35.4ms +/- 8.6%
    sha1: 27.9ms +/- 3.5%
    date: 170.5ms +/- 2.5%
    format-tofte: 79.9ms +/- 5.6%
    format-xparb: 90.6ms +/- 3.1%
    math: 160.3ms +/- 2.2%
    cordic: 54.8ms +/- 5.4%
    partial-sums: 63.8ms +/- 1.4%
    spectral-norm: 41.7ms +/- 4.6%
    regexp: 568.4ms +/- 0.9%
    dna: 568.4ms +/- 0.9%
    string: 522.5ms +/- 1.1%
    base64: 34.1ms +/- 9.0%
    fasta: 101.8ms +/- 4.3%
    tagcloud: 123.5ms +/- 2.6%
    unpack-code: 216.8ms +/- 2.0%
    validate-input: 46.3ms +/- 5.0%
  • »19.07.18 - 21:28
    Spectre660
    X5000/020 Odyssey-JIT MorphOS 3.11
    Total: 2679.3ms +/- 0.1%
    3d: 310.8ms +/- 0.5%
    cube: 96.1ms +/- 0.9%
    morph: 118.4ms +/- 0.5%
    raytrace: 96.3ms +/- 0.8%
    access: 404.6ms +/- 0.2%
    binary-trees: 15.3ms +/- 2.3%
    fannkuch: 302.1ms +/- 0.2%
    nbody: 65.2ms +/- 0.7%
    nsieve: 22.0ms +/- 0.0%
    bitops: 274.1ms +/- 0.3%
    3bit-bits-in-byte: 28.7ms +/- 1.7%
    bits-in-byte: 28.7ms +/- 1.2%
    bitwise-and: 44.5ms +/- 0.8%
    nsieve-bits: 172.2ms +/- 0.5%
    controlflow: 18.0ms +/- 0.0%
    recursive: 18.0ms +/- 0.0%
    crypto: 166.0ms +/- 0.7%
    aes: 100.6ms +/- 0.7%
    md5: 35.8ms +/- 1.6%
    sha1: 29.6ms +/- 1.7%
    date: 181.8ms +/- 0.6%
    format-tofte: 85.3ms +/- 0.8%
    format-xparb: 96.5ms +/- 0.8%
    math: 178.2ms +/- 0.3%
    cordic: 60.6ms +/- 0.6%
    partial-sums: 71.2ms +/- 0.4%
    spectral-norm: 46.4ms +/- 0.8%
    regexp: 605.1ms +/- 0.1%
    dna: 605.1ms +/- 0.1%
    string: 540.7ms +/- 0.2%
    base64: 37.3ms +/- 1.6%
    fasta: 118.2ms +/- 0.5%
    tagcloud: 125.9ms +/- 0.3%
    unpack-code: 211.2ms +/- 0.1%
    validate-input: 48.1ms +/- 0.5%
  • »19.07.18 - 22:18
    bigfoot
    With the Octane test, but with failing tests and regular expressions disabled, I get a score of 657 without JIT and 1089 with JIT.
    https://bigfoot.morphos-team.net/test/octane-without-regexp/
    Keep in mind that performance will improve in the future when I get a bit more time to work on this. This version is just the first version that's stable enough for general use.
  • »20.07.18 - 09:58
    Spectre660
    X5000/20
    AmigaOS 4.1FE
    Odyssey = 498
    Timberwolf = 424
    Ubuntu 16.04
    Qupzilla = 690
    Midori = 590
    [ Edited by Spectre660 20.07.2018 - 07:27 ]
  • »20.07.18 - 11:14
  • Leo
    Leo
    Posts: 417 from 2003/8/18
    To put it into perspective, here are some results on a phone & PC:
    - Android 8 / Chrome on LG G6 ARM Kyro 2.35Ghz (Feb 2017): 11 353
    - Linux 4.13.0 / Chrome on Intel Core i5 4590 3.7Ghz (4th generation, 2014): 36 456
    [ Edited by Leo 20.07.2018 - 12:35 ]
  • »20.07.18 - 13:25
  • ASiegel
    Apple iPad 2 bought in 2012: 1743
    2015 Telekom Android tablet with Mediatek ARM chip: 2232
    Mind you, both devices run either three-stage or four-stage Javascript JIT compilers... As stated, Odyssey currently has a single stage and there are plans to further improve it.
  • »20.07.18 - 14:09
    redrumloa
    Posts: 1424 from 2003/4/13
    I need proof bigfoot is human. From what I can tell he is a machine. A very efficient machine at that.
  • »22.07.18 - 05:01
    ernsteiswuerfel
    Posts: 545 from 2015/6/18
    OWB 1.25-JIT freezes at loading this page at about 322 KiB, whereas OWB 1.25 does not. Just tried a 2nd time to be sure.
  • »12.08.18 - 01:28
