JIT JS Bounty - update
    Posts: 1344 from 2004/2/8
    Awesome news, Thanks Bigfoot! I can't wait to try this at home (unfortunately I'll have to wait about 9 hours, darn).
  • »18.07.18 - 09:22
    bigfoot
    Posts: 510 from 2003/4/11
    As I mentioned, please don't expect miracles :)
  • »18.07.18 - 09:36
    No kidding. First miracle is that it's ready (well, sort of, I know). And still more miracles to come! This is going to be a good year for MorphOS, that's for sure.
  • »18.07.18 - 10:01
    bigfoot
    Haha, I meant speed wise :) The first level of JIT is quite naive in its approach, so it's not very fast, and Javascript is only a part of the browsing experience.
  • »18.07.18 - 10:09
    Posts: 915 from 2004/1/24
    \o/
  • »18.07.18 - 11:28
    zukow
    Posts: 650 from 2005/2/9
    Seems to be stable. Some things are slower, some faster:
    JIT VERSION:
    RESULTS (means and 95% confidence intervals)
    Total: 3523.1ms +/- 1.6%
    3d: 462.2ms +/- 5.0%
    cube: 111.8ms +/- 5.1%
    morph: 120.8ms +/- 5.2%
    raytrace: 229.6ms +/- 5.5%
    access: 666.0ms +/- 4.6%
    binary-trees: 47.8ms +/- 5.7%
    fannkuch: 331.7ms +/- 8.2%
    nbody: 272.9ms +/- 2.3%
    nsieve: 13.6ms +/- 4.4%
    bitops: 284.5ms +/- 2.4%
    3bit-bits-in-byte: 23.9ms +/- 4.1%
    bits-in-byte: 33.2ms +/- 3.5%
    bitwise-and: 43.3ms +/- 12.3%
    nsieve-bits: 184.1ms +/- 0.5%
    controlflow: 14.1ms +/- 4.4%
    recursive: 14.1ms +/- 4.4%
    crypto: 196.9ms +/- 0.8%
    aes: 116.4ms +/- 0.9%
    md5: 43.8ms +/- 1.3%
    sha1: 36.7ms +/- 2.1%
    date: 260.2ms +/- 0.5%
    format-tofte: 121.6ms +/- 0.5%
    format-xparb: 138.6ms +/- 0.7%
    math: 226.9ms +/- 0.8%
    cordic: 61.7ms +/- 2.0%
    partial-sums: 100.6ms +/- 1.3%
    spectral-norm: 64.6ms +/- 1.5%
    regexp: 655.3ms +/- 0.1%
    dna: 655.3ms +/- 0.1%
    string: 757.0ms +/- 1.6%
    base64: 86.6ms +/- 0.8%
    fasta: 137.3ms +/- 0.6%
    tagcloud: 183.6ms +/- 5.8%
    unpack-code: 264.6ms +/- 0.2%
    validate-input: 84.9ms +/- 1.2%
    NORMAL VERSION
    Total: 3092.4ms +/- 0.3%
    3d: 302.2ms +/- 0.7%
    cube: 85.8ms +/- 1.1%
    morph: 108.3ms +/- 1.8%
    raytrace: 108.1ms +/- 1.2%
    access: 371.6ms +/- 3.0%
    binary-trees: 34.4ms +/- 1.8%
    fannkuch: 191.9ms +/- 6.1%
    nbody: 106.7ms +/- 0.3%
    nsieve: 38.6ms +/- 1.0%
    bitops: 416.4ms +/- 1.2%
    3bit-bits-in-byte: 65.8ms +/- 7.5%
    bits-in-byte: 79.0ms +/- 0.6%
    bitwise-and: 132.4ms +/- 0.4%
    nsieve-bits: 139.2ms +/- 0.4%
    controlflow: 31.5ms +/- 1.2%
    recursive: 31.5ms +/- 1.2%
    crypto: 166.9ms +/- 1.6%
    aes: 79.6ms +/- 1.2%
    md5: 45.5ms +/- 2.9%
    sha1: 41.8ms +/- 1.9%
    date: 189.8ms +/- 0.8%
    format-tofte: 84.0ms +/- 1.2%
    format-xparb: 105.8ms +/- 0.7%
    math: 309.8ms +/- 0.4%
    cordic: 137.1ms +/- 0.4%
    partial-sums: 103.1ms +/- 0.9%
    spectral-norm: 69.6ms +/- 1.3%
    regexp: 686.3ms +/- 0.2%
    dna: 686.3ms +/- 0.2%
    string: 617.9ms +/- 0.4%
    base64: 82.4ms +/- 1.1%
    fasta: 114.6ms +/- 1.5%
    tagcloud: 138.3ms +/- 0.6%
    unpack-code: 210.4ms +/- 0.7%
    validate-input: 72.2ms +/- 1.5%
    [ Edited by zukow 18.07.2018 - 17:38 ]
  • »18.07.18 - 13:32
  • ASiegel
    Posts: 1396 from 2003/2/15
    @ zukow
    Not all applications are suitable for JIT compilation, of course. Things like Mandelbrot fractal generators work quite well already, though. The JIT gives a huge boost for these type of applications (up to 3x speed up in my tests).
    As for your results specifically, I have literally seen bigger differences between subsequent benchmark runs using the exact same browser version and Javascript interpreter.
  • »18.07.18 - 13:46
    bigfoot
    The linked archive has been updated with a new version that re-enables an optimisation that had accidentally been disabled in the previous release.
  • »19.07.18 - 07:46
    Akhem...
    Forbidden
    You don't have permission to access /test/OWB-JIT.lha on this server.
    Apache Server at bigfoot.morphos-team.net Port 443
  • »19.07.18 - 08:53
    bigfoot
    Fixed, thanks :)
  • »19.07.18 - 08:56
    bigfoot wrote:
    Fixed, thanks :)
    It's faster. Tested on 1,33 GHz iBook G4 and it did the Sunspider test in 4203 ms (vs 4754,3 without JIT). More benchmarks to come.
  • »19.07.18 - 11:29
    Spectre660
    Posts: 276 from 2015/6/30
    Just for reference what version of Sunspider ?
  • »19.07.18 - 13:33
    1.0.2
  • »19.07.18 - 13:54
    Spectre660
    Thanks.
    Will Post some X5000/020 Linux PPC results for baseline comparisons .
  • »19.07.18 - 13:59
    Spectre660
    Qupzilla
    Total: 3180.7ms +/- 0.3%
    3d: 300.0ms +/- 0.5%
    cube: 84.1ms +/- 0.3%
    morph: 109.6ms +/- 0.5%
    raytrace: 106.3ms +/- 1.4%
    access: 354.0ms +/- 0.2%
    binary-trees: 41.0ms +/- 0.8%
    fannkuch: 180.3ms +/- 0.3%
    nbody: 89.0ms +/- 0.4%
    nsieve: 43.7ms +/- 0.8%
    bitops: 557.1ms +/- 1.4%
    3bit-bits-in-byte: 74.3ms +/- 6.0%
    bits-in-byte: 95.8ms +/- 1.6%
    bitwise-and: 222.5ms +/- 1.1%
    nsieve-bits: 164.5ms +/- 0.3%
    controlflow: 58.0ms +/- 0.0%
    recursive: 58.0ms +/- 0.0%
    crypto: 192.9ms +/- 0.7%
    aes: 74.8ms +/- 0.9%
    md5: 60.7ms +/- 1.0%
    sha1: 57.4ms +/- 0.9%
    date: 185.3ms +/- 1.0%
    format-tofte: 88.6ms +/- 0.8%
    format-xparb: 96.7ms +/- 1.6%
    math: 378.2ms +/- 0.4%
    cordic: 144.9ms +/- 0.8%
    partial-sums: 150.2ms +/- 0.4%
    spectral-norm: 83.1ms +/- 0.3%
    regexp: 584.7ms +/- 0.2%
    dna: 584.7ms +/- 0.2%
    string: 570.5ms +/- 0.4%
    base64: 88.4ms +/- 2.1%
    fasta: 135.6ms +/- 0.5%
    tagcloud: 124.3ms +/- 0.4%
    unpack-code: 147.4ms +/- 0.5%
    validate-input: 74.8ms +/- 0.6%
  • »19.07.18 - 14:03
    Spectre660
    Midori
    Total: 3161.8ms +/- 5.2%
    3d: 356.3ms +/- 0.5%
    cube: 83.4ms +/- 0.9%
    morph: 156.7ms +/- 0.3%
    raytrace: 116.2ms +/- 1.3%
    access: 381.1ms +/- 0.9%
    binary-trees: 43.1ms +/- 0.5%
    fannkuch: 202.1ms +/- 1.7%
    nbody: 88.3ms +/- 0.4%
    nsieve: 47.6ms +/- 0.8%
    bitops: 494.9ms +/- 0.3%
    3bit-bits-in-byte: 82.3ms +/- 0.4%
    bits-in-byte: 104.7ms +/- 0.3%
    bitwise-and: 136.0ms +/- 0.0%
    nsieve-bits: 171.9ms +/- 0.6%
    controlflow: 46.7ms +/- 0.7%
    recursive: 46.7ms +/- 0.7%
    crypto: 187.2ms +/- 0.4%
    aes: 77.1ms +/- 0.3%
    md5: 57.1ms +/- 0.9%
    sha1: 53.0ms +/- 0.0%
    date: 223.6ms +/- 0.8%
    format-tofte: 103.6ms +/- 0.5%
    format-xparb: 120.0ms +/- 1.2%
    math: 264.5ms +/- 61.4%
    cordic: 69.1ms +/- 234.8%
    partial-sums: 117.2ms +/- 0.3%
    spectral-norm: 78.2ms +/- 0.4%
    regexp: 575.2ms +/- 0.2%
    dna: 575.2ms +/- 0.2%
    string: 632.3ms +/- 0.2%
    base64: 98.2ms +/- 0.7%
    fasta: 116.2ms +/- 0.4%
    tagcloud: 139.2ms +/- 0.6%
    unpack-code: 200.4ms +/- 0.4%
    validate-input: 78.3ms +/- 1.4%
  • »19.07.18 - 14:04
    OWB-JIT on PowerMac G5 2,7 GHz:
    Total: 2430.1ms +/- 0.6%
    3d: 280.7ms +/- 2.9%
    cube: 91.1ms +/- 4.3%
    morph: 98.3ms +/- 5.8%
    raytrace: 91.3ms +/- 4.4%
    access: 317.1ms +/- 2.4%
    binary-trees: 12.8ms +/- 2.4%
    fannkuch: 233.5ms +/- 2.7%
    nbody: 52.9ms +/- 2.2%
    nsieve: 17.9ms +/- 14.4%
    bitops: 244.5ms +/- 2.3%
    3bit-bits-in-byte: 21.4ms +/- 6.9%
    bits-in-byte: 28.1ms +/- 4.9%
    bitwise-and: 42.3ms +/- 4.1%
    nsieve-bits: 152.7ms +/- 3.3%
    controlflow: 12.3ms +/- 18.6%
    recursive: 12.3ms +/- 18.6%
    crypto: 153.8ms +/- 2.1%
    aes: 90.5ms +/- 1.2%
    md5: 35.4ms +/- 8.6%
    sha1: 27.9ms +/- 3.5%
    date: 170.5ms +/- 2.5%
    format-tofte: 79.9ms +/- 5.6%
    format-xparb: 90.6ms +/- 3.1%
    math: 160.3ms +/- 2.2%
    cordic: 54.8ms +/- 5.4%
    partial-sums: 63.8ms +/- 1.4%
    spectral-norm: 41.7ms +/- 4.6%
    regexp: 568.4ms +/- 0.9%
    dna: 568.4ms +/- 0.9%
    string: 522.5ms +/- 1.1%
    base64: 34.1ms +/- 9.0%
    fasta: 101.8ms +/- 4.3%
    tagcloud: 123.5ms +/- 2.6%
    unpack-code: 216.8ms +/- 2.0%
    validate-input: 46.3ms +/- 5.0%
  • »19.07.18 - 18:28
    Spectre660
    X5000/020 Odyssey-JIT MorphOS 3.11
    Total: 2679.3ms +/- 0.1%
    3d: 310.8ms +/- 0.5%
    cube: 96.1ms +/- 0.9%
    morph: 118.4ms +/- 0.5%
    raytrace: 96.3ms +/- 0.8%
    access: 404.6ms +/- 0.2%
    binary-trees: 15.3ms +/- 2.3%
    fannkuch: 302.1ms +/- 0.2%
    nbody: 65.2ms +/- 0.7%
    nsieve: 22.0ms +/- 0.0%
    bitops: 274.1ms +/- 0.3%
    3bit-bits-in-byte: 28.7ms +/- 1.7%
    bits-in-byte: 28.7ms +/- 1.2%
    bitwise-and: 44.5ms +/- 0.8%
    nsieve-bits: 172.2ms +/- 0.5%
    controlflow: 18.0ms +/- 0.0%
    recursive: 18.0ms +/- 0.0%
    crypto: 166.0ms +/- 0.7%
    aes: 100.6ms +/- 0.7%
    md5: 35.8ms +/- 1.6%
    sha1: 29.6ms +/- 1.7%
    date: 181.8ms +/- 0.6%
    format-tofte: 85.3ms +/- 0.8%
    format-xparb: 96.5ms +/- 0.8%
    math: 178.2ms +/- 0.3%
    cordic: 60.6ms +/- 0.6%
    partial-sums: 71.2ms +/- 0.4%
    spectral-norm: 46.4ms +/- 0.8%
    regexp: 605.1ms +/- 0.1%
    dna: 605.1ms +/- 0.1%
    string: 540.7ms +/- 0.2%
    base64: 37.3ms +/- 1.6%
    fasta: 118.2ms +/- 0.5%
    tagcloud: 125.9ms +/- 0.3%
    unpack-code: 211.2ms +/- 0.1%
    validate-input: 48.1ms +/- 0.5%
  • »19.07.18 - 19:18
    bigfoot
    With the Octane test, but with failing tests and regular expressions disabled, I get a score of 657 without JIT and 1089 with JIT.
    https://bigfoot.morphos-team.net/test/octane-without-regexp/
    Keep in mind that performance will improve in the future when I get a bit more time to work on this. This version is just the first version that's stable enough for general use.
  • »20.07.18 - 06:58
    Spectre660
    X5000/20
    AmigaOS 4.1FE
    Odyssey = 498
    Timberwolf = 424
    Ubuntu 16.04
    Qupzilla = 690
    Midori = 590
    [ Edited by Spectre660 20.07.2018 - 07:27 ]
  • »20.07.18 - 08:14
  • Leo
    Leo
    Posts: 419 from 2003/8/18
    To put it into perspective, here are some results on a phone & PC:
    - Android 8 / Chrome on LG G6 ARM Kyro 2.35Ghz (Feb 2017): 11 353
    - Linux 4.13.0 / Chrome on Intel Core i5 4590 3.7Ghz (4th generation, 2014): 36 456
    [ Edited by Leo 20.07.2018 - 12:35 ]
  • »20.07.18 - 10:25
  • ASiegel
    Apple iPad 2 bought in 2012: 1743
    2015 Telekom Android tablet with Mediatek ARM chip: 2232
    Mind you, both devices run either three-stage or four-stage Javascript JIT compilers... As stated, Odyssey currently has a single stage and there are plans to further improve it.
  • »20.07.18 - 11:09
    redrumloa
    Posts: 1424 from 2003/4/13
    I need proof bigfoot is human. From what I can tell he is a machine. A very efficient machine at that.
  • »22.07.18 - 02:01
    ernsteiswuerfel
    Posts: 570 from 2015/6/17
    OWB 1.25-JIT freezes at loading this page at about 322 KiB, whereas OWB 1.25 does not. Just tried a 2nd time to be sure.
  • »11.08.18 - 22:28
    NewSense
    Posts: 1561 from 2012/11/9
    I'm still using the 1st JIT Beta release, and that page loaded fully for me, and transferred to the next link, such as, CompterBase - audio-and-video without issue on my Mac Mini 1.5GHz
  • »11.08.18 - 22:50
