MorphOS features sooner - WiFi open networks
    Posts: 12543 from 2003/5/22
    > It's done already what you say. I was adviced here that EDIMAX EW-7206APg
    > was tested with Pegasos so that's the one I'm using now.
    Crumb was talking about USB to WiFi bridges, which come as small USB sticks, not about Ethernet to WiFi bridges, which are much larger and need extra power but have the advantage to work transparently for the OS and thus not require any driver.
    http://en.wikipedia.org/wiki/Wireless_network_interface_controller
  • »27.01.10 - 17:11
    Posts: 608 from 2003/4/11
    [quote]
    Andreas_Wolf schrieb:
    >> WiFi for MorphOS with all the bells and whistles won't happen anytime soon, neither
    >> for MorphOS 2.5, nor close to any (possible) PowerBook MorphOS release.
    >So jacadcaps's statement from August 2009 isn't valid any more?
    Obviously not, otherwise we are talking about a far, far away ibook/powerbook release
    >> even if limited to the broadcom apple stuff and even though there are
    >> reference implementations by now
    >"By now" = for 4 years ;-)
    If you can provide anything useful, just do so, otherwise just STFU.
  • »27.01.10 - 17:28
    > Obviously not
    Thanks for clarification. I'm sure that's not only to me news.
    I think that asking for clarification when confronted with mutually contradictive statements by different members of the MorphOS Team is a useful thing to do. And stating the fact that there are both open (reengineered) specs and open source drivers for Broadcom WiFi chipsets for some years (as opposed to just "by now") doesn't hurt either.
    You are not in the position to tell me what to do, I bet.
  • »27.01.10 - 18:39
    pampers
    Posts: 1068 from 2009/2/26
    Come one guys, take it easy..
    MorphOS 3.x
  • »27.01.10 - 18:49
    mihailod
    Posts: 170 from 2010/1/8
    I don't see what the issue is here? Some fools^h^h^h^h^h people want to open a bounty (couple of clicks for the admin) and put their money in (couple of more clicks for each fool^h^h^h^h person).
    Nobody has to pick that bounty up. Nothing needs to happen. Let just open it and see how much money we can get and maybe someone will rooll up the sleeves and do it.
    Let's keep it simple: Mac Mini ONLY, NO security. NO fancy GUI, just make it work. Later, it would be easier to build on that and incoproprate more I guess...
  • »27.01.10 - 19:43
    Well, I just wanted to point out that there is currently noone in the MorphOS team doing some work on WiFi. With that in mind, I don't see WiFi happen out of a sudden even if contradictive statements in the past exist.
    I have no objections against a bounty, I just wanted to make clear that even if reference implementations or relevant info exists for several years, it doesn't make this task any simpler.
    MorphOS is not Linux and being able to run make/configure doesn't qualify to add the whole wireless infrastructure to the system. If there will be anything provided by MorphOS team included in a future update, it won't be based on GPL code most likely, anyway, last but not least due to the closed source nature of the OS core.
    I can confirm that once you get the actual driver working in open mode, adding WEP support isnt really a big deal. Adding seemless integretation into the existing network UI to enter the password, isn't either. Adding WPA/WPA2 adds a new level of complexity, though.
  • »28.01.10 - 01:39
    jcmarcos
    Posts: 1178 from 2003/3/13
    SoundSquare wrote:
    you can never stop fools from insisting ;-)
    About fools, add me to the list, way on top: I didin't figure how easy it was to obtain a working MAC address (sniffing packets in the air), in order to pass through a MAC filter.
  • »28.01.10 - 09:41
    SoundSquare
    Posts: 1214 from 2004/12/1
    Thanks for the support, pal. Next time I'm about to come up with something alike, I'll remember that.
    the winking smiley should help you to handle that, don't take it personaly ;-)
  • »28.01.10 - 11:08
