                Posts: 297 from 2003/5/20
				Getting tired of loading the eztcp thread and then goto
last page after loading is finished. MZ isnt that fast
either
ok, things are getting better here, with Mosnet 0.17
Maybe its the fiddling with env and config files or that
i changed to built-in via_rhine network.
starting a smbfs share in shell and using plain
shell copy, i copy a 25.3mb file in 4 secs(counting out loud). Thats damn nice ~6.3mb/s.
Trying a bigger 733mb iso, it took 1 min 47 secs with a timer watch. thats around 6.8mb/s.
So atleast something works.
With ftp into the same pc computer (ftpserv on pc)
i get around 80k/s download , so thats really wierd.
Upload in either shell copy or ftp doesnt work, or its so
slow its barely transfering something.
settings:
mosnet/db/general.config i added :
tcp_nodelay=1
tcp_sendspace=16384
tcp_recvspace=16384
rfc1323=1
sb_max=32768
But scanning the mosnet binary, seems nearly all of the config options are
gone, if not they are not working.
rfc1323=1 will enable tcp_recv/sendspace to be greater than 64k, for whoever
needs this, if setting tcp_sendspace=65536 nothing will work, giving you
buffer errors.
These and alot of other options for ifconfig was found on google, searching for
ifconfig mtu, fconfig tuning, etc, there are loads if help, but nearly nothing
works on current mosnet.
Wierd thing is how download to pegasos nearly works in full 100mbit speed, and
upload doesnt even remotely remind of any transfering at all, could probably yell
the binarystuff to someone writing it down faster.
ENV:sana2/via_rhinepci_0.config is set to AUTONEGOTIATE
the network is plugged directly into a switch.
