Ambient is not displayed, Quark,Openfirmware
    Posts: 108 from 2005/4/3
    Ambient is not displayed, only text: Quark/Openfirmware
    I can with the Smartfirmware commands manualy do a boot from CD or Harddisk. Also i can view the contents of the CD/Hd. It is loaded, but failed to display the Ambient.
  • »25.11.05 - 11:16
    SoundSquare
    Posts: 1214 from 2004/12/1
    what Pegasos board do you own ? Peg1 ? 2 ?
    there are two boot images, one for each
    peg1 : bootpeg1.img
    peg2 : boot.img
    make sure you boot on the right one.
  • »25.11.05 - 11:38
    Hi Soundsquare,
    A Pegasos II G4, tried already both boot.img. It loads, but Ambient is not displayed. A "Quark/Open firmware" appears. Manually, i can load the images from HD and CD. MorphOSBoot 1.4.5 is also used.
    Visit my homepage at:
    http://www.angelfire.com/amiga/ex
  • »25.11.05 - 11:44
    SoundSquare
    remove all pci cards, or USB devices and try again.
    what does the serial debug output says ? can u check it ?
  • »25.11.05 - 11:49
    Hi SoundSquare,
    Allready removed PCI cards, plugs. Removed temporary the HD and CD. Maybe the bios must be flashed ? And how to do that ?
    Grts, Amigaharry
  • »26.11.05 - 08:01
    Posts: 2565 from 2003/2/24
    Does it allways stop, or only say 4 out of 5 times ?
    Cos that what I had some time ago, and it turned out that MorohOS
    didn't like my HD-setup with "holes" in the partioning.
    So, try booting from CD and remove all non-essantial partitions (and
    make sure that the remaining are next to another).
  • »27.11.05 - 09:14
    Hi Kronos,
    A while ago, i had the problem too. However, it starts always after some resets or booting from CD. Now, it always stops. Tried already to boot from CD (MorphOSBoot) only, with removing of the harddisk.
    No improvements..
    Grts, Amigaharry
  • »27.11.05 - 16:13
