MiamiDX control panels for ezTCP
    Posts: 408 from 2004/7/15
    I wonder what do you think about making ezTCP compatible with MiamiDX control panels? I studied their API and now i see it's perfectly possible. There's nothing really Miami-specific there except traffic meters (can be just disabled at first stage and added later).
    iPod, iBook, iMac,... iRobot?
  • »12.10.05 - 05:22
    Posts: 2730 from 2003/2/24
    I'd say: if it really is doable, then do it! :-)
  • »12.10.05 - 06:02
    Posts: 918 from 2004/1/24
    If ezTCP has MiamiDX control panel support, I might even start using ezTCP ;-)
    But yes, it would be highly appreciated.
  • »12.10.05 - 06:06
    On second thought, the best thing would be if everything needed to get going and use the stack was included in the same package (including GUI of course), without depending on the user first downloading MiamiDX in order to rip its GUI.
    But I still think it should be cool as an *alternative*! :-)
  • »12.10.05 - 06:18
    Great, i consider this question to be closed. I will do it, it is quite possible. I already imported MUI.miamipanel and MUINL.miamipanel source code into my development tree. This appears to be a really good approach, greatly saves time and makes reuse of already available resources.
    I'll start the intergation right after DHCP and syslogger.
    I even start to think about renaming to OpenMiami since the project starts to turn into opensource Miami reimplementation.  :-D
  • »12.10.05 - 06:19
    SoundSquare
    Posts: 1214 from 2004/12/1
    and of course, you'll share the bounty money with Miami authors.
    j/k
  • »12.10.05 - 08:43
    klesterjr
    Posts: 196 from 2005/4/1
    j/k
    The bounty is for Sonic's "work" on ezTCP -- not for the software itself.
    Making ezTCP "compatible" with Miami's control panel is no different than making software that is "compatible" with Windows (or MorphOS!).
    [ Edited by klesterjr on 2005/10/12 9:29 ]
  • »12.10.05 - 09:24
    Posts: 1932 from 2003/10/19
    Sonic thats sounds like a great idea. I havent used those 3rd party GUI replacements for Miami before, but I have seen screen grabs with them. If they are open source then go for it. Once DHCP and easy setup is done I will be ready to test this stack!
  • »12.10.05 - 12:03
    Posts: 1087 from 2003/3/24
    Great idea Sonic!
    I like Gelbes-Panel so much.
    Oh and keep up the good work!
  • »12.10.05 - 18:44
    There are several opensource panels (and i will bundle two of them) and there are some closed-source ones (you'll just be able to use them). Gelbespanel is not opensource (well, if the author ever contributes the code for native build i'll definitely include it too), but it will work. Just download, install and use.
  • »13.10.05 - 03:17
    Velcro_SP
    Posts: 929 from 2003/7/13
    I don't exactly understand this? Is "control panel" the MiamiDX GUI? Or is this some add-on released by a third party on Aminet?
    I don't think ezTCP users should be required to go and download MiamiDX demo. You want to have everything in one archive for easy installation.
    Although I have sometimes thought it might be nice to make use of Miami demo's user-friendly DHCP detection and setup. The settings are determined and then just plugged into whatever stack. That is not violating any shareware terms AFAIK and Holger Kruse should not complain anyway as he doesn't sell or support Miami anymore.
    Pegasos2 G3, 512 megs RAM
  • »14.10.05 - 07:10
    Third party addon, of course. Not main GUI. :) There are plenty of good panels for Miami, the most favourite is Gelbespanel. There are at least two opensource panels under GPL so i'll include them into the distribution so that they'll become a standard part.
    Of course MiamiDX won't be required.
    Hm, didn't see this feature since never used MiamiDX (stuck with Genesis). I'll look at it. Probably this could be transformed into some kind of "Internet connecion wizard" like in Genesis, Windows or Linux.
    I guess this wizard won't be there with first release (short of time), but noone prevents from adding it in future.
  • »14.10.05 - 07:27
