                Posts: 741 from 2003/2/24
				... and I cant sleep. So I thought to do something usefull:
I've asked Targhan to create two new bounties.
What do you think ?
Improved default icons in Ambient
Goal: Improve the default icon support
in Ambient to a usefull state.
Requirements:
- Preferences Editor that can assign
an icon and one or more actions to perform
on a doubleclicked file.
- A menu for each file with its actions added
to it's popup menu.
- Filetype recognition by header and
an editor to add/change headers and a "smart"
learning by passing sample files.
(Like whatis.library, or even better like Opus Magellan)
Archivesupport in Ambient
Goal: Make archives accessible as if they
were directories in Ambient
Requirements:
- Add support for displaying/handling archives
to Ambient as if they were directories.
- Add an entry to compress a directory to each directory popupmenu.
- Support if possible all archivetypes (fex XAD.library).
Minimum requirement is: lha,zip,tar.gz,tar.bz
[ Edited by Robin on 2005/9/13 5:25 ]
