ezTCP progress report
    Robin
    Posts: 741 from 2003/2/24
    I like the MiamiDX-GUI . It gives a quick overview
    and at the same time let you easily configure the stack.
    Perhaps a user/expert-modus where "dangerous" settings are
    hidden from normal users.
  • »14.08.05 - 15:36
    Wishmaster
    Posts: 342 from 2003/6/29
    I hope this TCP-Stack will be stable and ultra fast.
    Concerning the GUI I would say something similar to MiamiDX for a start could be used.
    Will PPPoE be supported ?
    Pegasos PPC
  • »14.08.05 - 17:26
    Krashan
    Posts: 1107 from 2003/6/11
    Hmm, I want to avoid such complicated GUI.
    Will PPPoE be supported?
    Not in the 'bounty' release. After that everything will be possible: as ezTCP is planned to be opensourced, someone can add PPPoE, or even I can do it if it is openly documented standard (but well I do not have a place to test it...).
  • »14.08.05 - 18:59
    Posts: 1932 from 2003/10/19
    I think the GUI should be simple and easy to use. That is the number one thing I would say. MiamiDX is a mess. i dont even use the GUI any more since I set it all up.
  • »14.08.05 - 20:18
    analogkid
    Posts: 722 from 2004/11/3
    I share Robin's opinion, the GUI should be simple, in the style of MiamiDx, with an additional expert mode.
  • »14.08.05 - 20:29
    Posts: 919 from 2004/1/24
    Though it might be too much asked for the bounty release, what about a wizard? A step-by-step setup manager for the common user. With such a wizard present, a more complex/complicated gui (maybe like miamidx?) shouldn't be a problem or even be welcomed by more advanced users.
  • »14.08.05 - 21:14
    Posts: 2732 from 2003/2/24
  • »15.08.05 - 07:14
    Posts: 1087 from 2003/3/24
    I think a GUI is very importent.
    But First we need ezTCP, without GUI but with a XML Configfile. Krashan could release ezTCP with some Configfiles with DHCP and static IP.
    And then an ezTCP Gui bounty could be started with a setup Wizard, and a GUI with an "Advanced User Mode" switch.
  • »15.08.05 - 07:36
    ironfist
    Posts: 254 from 2004/4/22
    Doesn't the current bounty demand a GUI?..
  • »15.08.05 - 09:06
    Posts: 2095 from 2003/6/4
    For program usage I would like a very simple gui. Rather like Genesis than Miami.
    IMHO the preferences do not need a gui which addresses all possible options as long as editing a configfile will not be too cryptic. A good documentation should be enough. Remember that MOS is not a n00b system.
  • »17.08.05 - 12:29
    Posts: 278 from 2003/3/4
    I guess that if it is called "EZ" it should be easy for everyone setting it up and control it.
    It does not prevent the use of an editable config file.
  • »17.08.05 - 13:03
