SSHCON progress report
    Posts: 3326 from 2003/3/5
    The SSHCON package is slowly getting better and better!
    This weekend brought the remote alt key support in PowerTerm as requested by users on #morphos. I also updated the site a bit and killed a few bugs. Another update for the donors is coming soon.
  • »31.07.05 - 20:08
  • Targhan
    Posts: 2833 from 2003/2/7
    Your timing, jaca, could not have been better!
    We now have permissions in the Downloads section PER FILE! Also, per your position, you could also distribute beta's via the PM system! In fact, services of morphzone are finally moving toward the ability to have truely structured beta-test groups.
    And folks, if you were wondering about SSHCon, the early beta provided to me has really helped getting MorphZone put back together! (Thanks Jaca!)
    :idea:Targhan
  • »31.07.05 - 20:22
    Sounds great, I'm gonna give this new system a try in the evening :-)
    Btw. PowerTerm.mcc is nearly complete now - what still needs to be done is full utf i/o support (there's no input handling yet  :-D
    I would also like to thank for the donations - they really boost my motivation. Thanks guys!
  • »01.08.05 - 04:47
    SSHCON is getting closer and closer to a release! The last nightly build brought quicklaunch support (autoconnect on startup), more hotkeys and various fixes.
    Thanks to March I've been able to fix a few more input handling incompatibilities (alt+enter, etc).
  • »17.08.05 - 10:41
