MUI versions
    artickfox
    Posts: 101 from 2004/4/17
    I can suggest to make a MUI version of the most famous emulators, like UAE, MAME or SNES9x.
    Actually Frodo is also in MUI version:
    http://www.lehtoranta.net/
    http://www.lehtoranta.net/FrodoUusi.png
    It's rocks! I really hope to see more "MUI versions"!
    Many emulators are "optimized" for MorphOS, often they must used by shell, or use non-native libraries (like the Mame 0.71, you must install some compound from Aminet).
    Also some GUIs are done with ARexx (like UAE gui), and it's not included into MorphOS 1.4/1.4.2 distribution. And not all Pegasos user's, like me, have AmigaOS 3.1/3.9, and have manner to retrive easly the arexx library (it's not on aminet  :-/ ).
    I have nothing against Shells, but is easy make wrongs digit all commands and parameters by text (but it's still great for other works, I ever use it to de-compress archivies...).
    I use often Pegasos for emulators, so I can suggest:
    Mame, UAE, SNES (altrought exist alredy a good GUI).
    Also, exist a good ZX-Spectrum emulator for Amiga 3.1/3.9 or MorphOS?
    Virtual Paws:
    http://www.furryitalia.net/virtualpaws/index.htm
    Italian furry videogame site
    Furry Italia
    Italian Furry Comunity
    - Owner of a Pegasos 2/G3 -
  • »07.06.04 - 16:58
    Posts: 919 from 2004/1/24
    Ehhhm, there is already a great MUI GUI for Snes9x done by Tokai.
  • »07.06.04 - 20:17
    tokai
    Posts: 1289 from 2003/2/25
    and don't forget that MAME has a very nice and informative inbuild MUI GUI already!!! :-)
    and fully reimplemented rexxsyslib.library will come with morphos1.5 i heard :)
  • »07.06.04 - 20:47
    tokai
    just another info:
    it also depends on the emulator/port.
    e.g. for snes9x or mame it does not make sense to make such highly integrated MUI GUI like in frodo. That has a few resons. e.g. MAME is heavy updated... and integrating a MUI GUI into official source tree is not possible easily, because the source has to compile on all systems. So the only possibility is to code a frontend (which uses MUI already) which can be easily linked.
    That's what I think. :)
    but feel free to compile snes9x and integrate snes9xstarter. snes9x sources are available and a bit older snes9xstarter source code is available on mdc.morphos.net (maybe i'll upload the new version when i have time).
    regards,
    tokai
  • »07.06.04 - 20:54
    artickfox
    Haaa! Finally a new Arexx working! ;-)  ;-)
    Anyone whitout a AmigaOS3.1/3.9 have some trouble to make work Arexx progrs with actual release...
    Virtual Paws:
    Furry Italia
  • »07.06.04 - 21:16
