Posts: 2732 from 2003/2/24
SDK also comes with examples for several things. Better look there first before looking elsewhere!
Which you of course find on the same download page as the OS itself:
http://morphos-team.net/downloads
If you don't have ANY programming experience, might not be best to start with MorphOS specific stuff...
I think this is true, then you will have a learning curve on two fronts! Or maybe start with a higher level programming language than C even.
A little depending on your suppornness level of course.
I think Krashan's excellent tutorial is a good start:
Those articles are really great, and very well written. As always,when Krashan is involved...
MorphOS is Amiga
done right!
MorphOS NG will be AROS
done right!
