Playing MODs in AmiNet Radio player
    Intuition
    Posts: 1116 from 2013/5/24
    > I have all kinds of xad/xfd/xpk stuff installed and I often get confused as to which does what.
    There's a nice summary by the 'X-Systems' author:
    http://cd.textfiles.com/amigaplus/sonderheft26/Tools/Packer/xad/X-Systems.TXT
    Thanks Andreas, that was a nice refresher.
  • »13.10.13 - 21:38
    WeiXing3D
    Posts: 327 from 2012/6/13
    @Andreas_Wolf
    I've been in a business trip and away from my computer, so I haven't tried anything. But I did install the latest available versions of the player plugs in ANR, but the mod stil didn't play.
  • »15.10.13 - 20:08
    Posts: 12547 from 2003/5/22
    Have you activated the ANR players in the ANR prefs? You may additionally give them a priority higher than that of all other installed and activated ANR players and see if that helps.
  • »15.10.13 - 20:23
    WeiXing3D
    @Andreas_Wolf
  • »15.10.13 - 23:34
    hooligan
    Posts: 1948 from 2003/2/23
    I downloaded the mod.somewhere in time, downloaded ppunpack, unpacked the mod file and it plays just fine with both ANR (Modplug replayer) and UADE right away. Are you *really* sure you're trying to play the unpacked file instead of the powerpacked one, as if none of the players can't play ithe module it suggests this.
  • »16.10.13 - 02:38
    WeiXing3D
    I extracted to mods last Sunday. The first one (Assassin) plays fine in ANR, but that is not the case with Somewhere_In_Time. I can only give it another try this Thursday, my local time, when I come back from this business trip.
  • »16.10.13 - 03:12
    I don't think he tried to play it in UADE as the last thing he wrote about UADE in this thread was that both UADE versions he installed lacked the executable file (while his screenshots prove the opposite).
  • »16.10.13 - 06:21
    hooligan
    BTW I use the excellent Exciter Player as UADE frontend
    Link: http://uade.fatmagnus.ppa.pl/index.php
  • »16.10.13 - 06:44
    XzIt
    Posts: 250 from 2005/1/19
    well im using hippoplayer witch supports the packed mod files and plays them as is.
    just need the xpk libs etc installed.
    http://www.exotica.org.uk/wiki/HippoPlayer
    http://aminet.net/package/mus/play/hippoplayer
    X
    [ Edited by XzIt 18.10.2013 - 15:14 ]
  • »18.10.13 - 11:12
    "Loads and decompresses XPK, FImp, PowerPacker, LhA, LZX and Zip files" reads more like it doesn't use XPK to decrunch PowerPacker files but either has the PowerPacker decruncher inbuilt or uses another library for this.
    Edit: I just had a look into HiP.guide and it seems I'm right: HippoPlayer needs powerpacker.library or the XFD libs installed in order to decrunch PowerPacker files.
    [ Edited by Andreas_Wolf 20.10.2013 - 22:19 ]
  • »18.10.13 - 11:50
    Posts: 19 from 2013/6/15
    @XzIt
    How did you manage to play mods with HippoPlayer on MorphOS? I've been always getting "Couldn't allocate CIA timer(s)!" error.
  • »18.10.13 - 16:28
    XzIt
    ill post some images of my prefs settings, just need to have some mins to do it ;P
    X
  • »19.10.13 - 15:22
    Posts: 2217 from 2003/2/24
    I gave a quick try with this too, but didn't get it to work yet. I switched PT replayer to use fastram, configured AHI unit... and enabled VBlank timing to get rid of CIA timer complaining, but it still hangs when I try to play. It also gives a hit in debug log when started.
  • »01.11.13 - 06:50
    This is some step forward. With the aforementioned settings, HippoPlayer played Spacedeliria and some other modules. However, the quality of sound is quite poor, and the system becomes completely unresponsive while playing.
  • »01.11.13 - 16:17
    XzIt
    Finally got back to my mosbox, but didt get Hippoplayer working.... ;(
    I had it up and working on my old machine, that hw has said godnight.
    so i cant get it up and running again atm, i will reply here as soon as i get it working again, might be missing some 3rd part software to get it to work dunno....
    Sorry
    X
  • »03.11.13 - 13:14
  • k8o
    k8o
    Posts: 57 from 2013/5/29
    Hey, I didn't want to start a completely new thread for this so just continuing this one...
    AminetRadio is pretty much the nicest mod replayer for morphos, and nicely expandable for custom/exotic formats too, but it used to crash soooooo much! So I used UADE and ExcitePlayer for exotic formats which is good....
    However, since MOS 3.10 I have found that AminetRadio is not crashing like it used to! This is pretty awesome, not sure of the many under-the-hood changes have helped stabilize this programme but so far all is good, thanks, just reporting my user experience :)
  • »09.04.18 - 10:16
    ernsteiswuerfel
    Posts: 571 from 2015/6/17
    Hey, who would have thought that! :-) I abandoned AminetRadio for the same reason, but it seems I should revisit it.
  • »10.04.18 - 07:31
