MorphOS Developer
Posts: 508 from 2003/4/11
My card is a genuine Radeon 9800 PRO 256MB Mac Edition featuring the R360 chipset (XT). It has also installed a brand new Zalman cooler plus full set of heatsinks. The card is running cool and I can verify that I have no issues of overheating. The card was running smooth under OSX in a Quicksilver previously, if that helps.
OK, then please use the bug report tool as I mentioned earlier. Doing so gives me valuable information about your hardware that will help me in figuring out what the problem might be.
Some applications I tested and failed, may indeed rely on SDL. Who should I inform in that situation? Because, if I swap the card with my old Radeon 9000, the applications (and the system in general) run back on normal.
The one issue you described (black screen, but sound is playing) could maybe be something like SDL not handling a different pixel format correctly. Could of course also be something else, but that was the first possibility that sprang to mind.
If you don't mind swapping cards, try booting with each of them and launching the 'GraphicsBoards' tool and note down which pixel formats each card supports.
How can I determine whether it's an individual application's fault or a more generic problem relying on the drivers issue?
That can be quite difficult to do. If you're in doubt, you can always file a bug report for it and then we can look into it.
I haven't found the time to investigate thoroughly the problem with Ambient lagging (that only gets fixed via reboot) but I can verify that it happens when I start moving OWB's window and when I open a txt file (I may need to open and close the txt file once or twice before the problem starts).
If you can reproduce it that easily, do this:
1) Reboot your computer.
2) Open a shell
3) Change the directory to one of your hard disk partitions by typing its name followed by a colon
4) Type 'getramdebuglog' (without the quotes) but don't press enter yet.
5) Do whatever it is it takes to reproduce the problem
6) Activate the shell window and press enter
7) Wait 5 seconds
8) Reboot, file a bug report, write a short description and paste the contents of the 'morphos.log' file that was created on the partition you chose.
