Henes wrote:
@dekanyz
To delete the current picture in Showgirls, just press the "delete" key on your keyboard.
To enable/disable the auto rotation based on Exif info, go to the Settings menu -> Setup -> General -> [x] Correct image orientation.
The Delete key steps up in the current directory on normal view, In full screen mode, it does nothing.
I know where to switch on the auto rotation feature.
The problem is, that if I edit the picture (and save it too), the rotation is handled badly. Probably it is rotated based on Exif info and is saved as it stands, but the Exif info will contain further the same rotation info, so next time it will rotate again (and make a bad rotation).
The mentioned lock by cropping issue is corrected in the latest version.
