wish list - feel free to expand.
    bash64
    Posts: 934 from 2010/10/29
    http://foo2zjs.rkkda.com/
    Printer driver for my color laser jet cp1025nw.
    Most games fixed to run on powerbook g4 laptop.
    G5 supporting more than 1GB of ram. Preferably 4GB minimum.
    Bugs in Transfer fixed. It gives me lots of issues when updating my website.
    Ambient Docs.
    Helios working with fw800 and not just fw400.
    My jbod box only does fw800.
    I'll think of more later.
    Very happy with everything so far.
    USB bug making life hard right now but will try 3.3 update, maybe it will go away.
    Powermac G5 2.3ghz 2GB, ATI 9600 Pro
  • »23.09.13 - 22:30
    I second the desire for better printer support (although I have two inkjets that work now).
    Better game support for the R300 cards would be nice (or how about something more powerful).
    G5 memory should be at least 1.5 to 2 GB.
    I'm not sure I care about firewire support.
    Only one of my MDDs is an FW800 and I have an NEC firewire board on the other so I can use fw400 on either.
    How about USB 3.0 support?
    Better integration with UAE and JIT translation.
  • »24.09.13 - 00:52
  • esc
    esc
    Posts: 152 from 2013/5/28
    My "wish list" in this order:
    1 - Multi core processing
    2 - >1gb ram support
    3 - Better R300 drivers, especially warp3d (come on, I really wanna replace my a4000! :P )
    4 - Upgrade process incrementally, i.e. without needing to boot to media
    5 - "App store" to manage system software, officially supported software, and updating
  • »24.09.13 - 02:33
    Posts: 2973 from 2003/3/5
    Fund a bounty?
    I haven't seend any bugreports sent via our bug report system. Make sure they are as detailed as possible.
  • »24.09.13 - 08:45
    bigfoot
    Posts: 508 from 2003/4/11
    4GB is the maximum you can address in a 32 bit system. Due to Amiga compatibility, the upper 2GB of the address space can't really be used. MorphOS reserves the first 512MB of the address space for its own purpose (ROM modules, emulation, etc). Thus, the maximum you'll see is 1.5GB.
    Can't happen in an Amiga-compatible system.
    Won't happen. It's simply a support nightmare and there's between no and a negative amount of advantage to doing that.
  • »24.09.13 - 09:29
    Crumb
    Posts: 730 from 2003/2/24
    -hardware accelerated Cairo
    -pixel shaders
    -more G5s (PCIe ones and iMac G5)
    -some kind of asymetric support for multicore systems (for number crunching, as described by Krashan)
    -ftp server/samba or some way to interchange data by network built in as default
    future:
    -x86-64 support.
    -64bit memory handling
    -smp
    -box with PowerPC emulator for legacy stuff.
    -java (for Eclipse mostly)
  • »24.09.13 - 09:55
    Posts: 12078 from 2003/5/22
    > >1gb ram support
    This has always been the case, except for the G5 port.
  • »24.09.13 - 10:31
    Is the reason for MorphOS on G5 supporting only 1.0 GiB RAM instead of 1.5 GiB that MorphOS reserves 1.0 GiB address space instead of 0.5 GiB for its own purpose on those machines? If yes, why does MorphOS need to reserve more address space on G5 than on G4?
  • »24.09.13 - 10:40
    bash64
    Fund a bounty?
    Yeah, I think it would be worth it to me to start a bounty for the printer.
    I will send in a bug report for Transfer.
    It does some very annoying things.
  • »24.09.13 - 12:46
    bash64
    Can I get the other missing 2GB as a ramdisk?
    Thats all I am looking for.
    :-D
  • »24.09.13 - 12:49
    dekanyz
    Posts: 94 from 2013/2/6
    - A newer gcc (g++), which supports C++0x.
    - Some major bug corrections.
    - Some minor changes in te existing tools (ShowGirls, OWB, ...)
    - Working MUIBuilder.
    - A well working SMBFS.
    - A nice User Manual.
  • »24.09.13 - 15:31
    Crumb
    :-D
    That would rock :-) Using extra gfx card ram as ram disk would be nice on old Efikas too (64MB for gfx and 64MB for ramdisk)!
    [ Edited by Crumb 24.09.2013 - 17:09 ]
  • »24.09.13 - 16:08
    Jupp3
    Posts: 1193 from 2003/2/24
    bash64,
    I admit I haven't tried every game lately, but I thought most games worked anyway?
    I can only think of 3 games that don't work, that some people might care for: Heretic II, Shogo and last but not least, Wipeout 2097. Definitely not "most". All of these use warp3d (or minigl) which is why they don't work for now. (Of course there are some small PD games that use W3D aswell, but I don't remember seeing any good one...)
    TinyGL has been updated a lot lately, and likely some games might be a bit broken on ALL supported hardware (you mentioned "games not working on PowerBook").
    Of course there are some other issues, such as texture transformations not being supported yet on R300 (I think?), that might make some games work badly on PowerBooks (and other R300 hardware).
  • »24.09.13 - 16:58
    Posts: 564 from 2004/4/15
    - Open Gl 2.0 + Open Gl Es 2.0 Support
    - hardware accelerated Cairo
    - ftp and nfs integration in Ambient
    - Cups port
    - Qt port
  • »24.09.13 - 17:16
    defender
    Posts: 247 from 2011/4/24
    New screenmodes for Powerbook would be nice.
    For example 800x600 640x480 so I can run my 1941 deluxe and
    Gianas return or Word me up XL again on Fullscreen.
    OWB does not support shopping at mytoys.de it says OWB does not
    accept cookies ?! thats annoying.
    Most other things are just fine for me :-)
  • »24.09.13 - 18:38
    stephen_robinson
    Posts: 746 from 2007/4/22
    Nap enabled for the G5, my Powermac runs hotter under MorphOS than MacOS X, that aint't right.
  • »24.09.13 - 18:47
    connor
    Posts: 570 from 2007/7/29
    wmlbpynt.png ???
  • »24.09.13 - 19:01
    tolkien
    Posts: 502 from 2013/5/29
    A complete programming IDE to make life easier.
  • »25.09.13 - 09:14
    bash64
    @jupp3
    When 3.2 was released it was found that most games would not run (I tried most of them) because the powerbook g4 has only one resolution and most games expect the monitor to support much smaller resolutions like 640x480, not 1440x900.
    I have trouble running 2 out of 3 of the Quakes out there.
    Plus a lot of other things.
  • »25.09.13 - 14:02
    bash64
    :-D
    Can anyone make the 2GB of extra ram available for a ramdisk?
    I remember on the original Amiga I had 3 different types of ram available and some of it was only available for data usage because it was too high in memory to be used by the cpu.
  • »25.09.13 - 14:04
    Posts: 1031 from 2004/9/23
    bash64,
    There never was such thing. The memory types you mention are Chip, Fast and Rangermem, which was added by some A500 memory boards and the 512KB extension of the A2000A model.
    Rangermem was simply very slow, so it got low priority on usage.
    Sure one could create a 2.0GB ram disk using the rest of the memory, but I donĀ“t think its worth the time required to create a proper driver.
    Geit
  • »25.09.13 - 14:57
    "Client will be available for different platforms as AmigaOS, AROS, MorphOS, Windows, OsX, Linux, indieGO!"
    http://amigaworld.net/modules/news/article.php?storyid=6875
    ...as well as:
    "In the moment a "true" app store is underway for AROS, AmigaOS and MorphOS."
    http://amigaworld.net/modules/newbb/viewtopic.php?topic_id=38200&forum=2#718025
  • »26.09.13 - 00:18
    boot_wb
    Posts: 874 from 2007/4/9
    A bounty for LibreOffice to finally be set up (money waiting here guys!)
    A nice MUI GUI for MLDonkey with funky graphs (ie like uTorrent).
    Integrated network file/folder sharing/mounting.
    A gpu dnetc client.
    Android emulation to allow sideloading apps,, or whatever the kids do these days :-)
    Free beer and chicks. And world peace.
    In that order.
    [ Edited by boot_wb 27.09.2013 - 00:52 ]
    www.hullchimneyservices.co.uk
    Windows free since 2011!
  • »27.09.13 - 00:52
    WeiXing3D
    Posts: 327 from 2012/6/13
    A self configuring E-UAE emulator using Amiga Forever CD, like J-UAE in AROS I caros.
  • »27.09.13 - 03:53
    WeiXing3D
  • »27.09.13 - 03:53
