Open Power
    minator
    Posts: 371 from 2003/3/28
    [...] Motherboard maker Tyan is creating its own system boards, which other server makers will be able to buy to create Power8-based machines [...].[/i]"
    Be interesting to see what they come up with and more importantly, the price.
    I wouldn't expect to see a lot of expansion but expect lots of memory slots.
    You won't be able to make much use of all the multiple cores/threads but then again that leaves a huge wodge of cache (36MB?).
    [ Edited by minator 26.04.2014 - 00:19 ]
  • »25.04.14 - 15:51
    Posts: 12547 from 2003/5/22
    Somehow, I find the existing ATX reference board more interesting than whatever server boards may come, even though there seem to be only 2 expansion slots on it.
  • »25.04.14 - 19:27
    minator
    I suspect they'll be remarkably similar.
    What they really need to do is cost reduce the POWER8 chip.
    It currently has a set of high speed interconnects that are there for connecting to other POWER8 chips. They are completely useless on that board.
    Cut those off and you could put the memory busses on chip (they're currently on a North bridge).
    That would cost less and save a load of power in the process.
    I suspect you may see this happen but it'll likely be a year or two away.
    BTW I was wrong about the cache. It's 96MB (!) on chip and a further 128MB on the north bridge.
    I forgot how much of a monster that thing is!
  • »25.04.14 - 23:41
    It's 16 MiB on the Centaur.
  • »26.04.14 - 14:46
    SKOLMAN_MWS
    Posts: 107 from 2006/10/24
    https://plus.google.com/u/0/111282580643669107165/posts/Uwh9W3XiZTQ
    _
  • »01.05.14 - 13:22
    SKOLMAN_MWS
    New server with 8 core 1.5 GHz Power8 http://servergy.com/portfolio_page/cts-1000/
    http://www.computerworld.com/s/article/9247147/Servergy_now_the_first_company_outside_IBM_to_build_Power_server
    [ Edited by SKOLMAN_MWS 04.05.2014 - 02:14 ]
    _
  • »03.05.14 - 19:48
    Posts: 2730 from 2003/2/24
    Are you sure this is Power8? ;-)
    The physical size, the power consumption, the chache size, the amount of cores, the clock, etc, etc suggests some semi-boring SoC from Freescale if you ask me...
  • »03.05.14 - 21:01
    boot_wb
    Posts: 874 from 2007/4/9
    Freescale PowerPC P4080 8 core 1.5 GHz
    http://servergy.com/userguide/Default.htm (Technical Specifications section).
    www.hullchimneyservices.co.uk
    Windows free since 2011!
  • »03.05.14 - 21:16
    SKOLMAN_MWS
    Fact, sorry. :-)
    From what is known so far only the new Nitendo Fusion Terminal is to have 8 core Power8
    http://www.redgamingtech.com/nintendo-fusion-terminal-fusion-ds-rumor-analysis/
    _
  • »03.05.14 - 22:03
    e500mc core, an eight core 32 bit processor.
    I'm really not interested in this company's stuff.
    They seem to look for crappy processors.
    Why not use the the T4080?
    [ Edited by Jim 03.05.2014 - 20:47 ]
  • »03.05.14 - 22:39
    SKOLMAN_MWS wrote:
    Fact, sorry. :-)
    After being burned by rumors from IBM and Nintendo on the specs of the WiiU, I find these specs less than believable.
  • »03.05.14 - 22:44
    This article is very badly researched and ignores facts that have been publicly documented by Servergy and covered by the press for 1.5 years. Ironically, Servergy hosts an uncommented copy of this rubbish on its website.
  • »04.05.14 - 11:56
    Yes, as sorted out 1.5 years ago:
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=3&topic_id=7183&start=830
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=3&topic_id=7183&start=860
  • »04.05.14 - 12:02
    Btw, does anybody have news on the P-Cubed? The last marginal sign of life I saw was from October 2013 (and that was from Freescale, not even from Servergy itself).
    > They seem to look for crappy processors. Why not use the the T4080?
    Because they obviously can't use a future chip for a device that's been available for months and that started being developed years ago, and because, as you know, they already announced the CTS-1000's successor with T4240:
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=3&topic_id=7183&start=929
    And after that, they intend to go for POWER8 (or derivative):
    "The company intends to extend its product line by developing future OpenPOWER-compliant systems based on IBM’s POWER microprocessors"
    http://servergy.com/servergy-joins-the-openpower-foundation/
  • »04.05.14 - 12:46
    Nintendo took no part in those misinformation coming from IBM.
  • »04.05.14 - 13:33
    They didn't counter it either.
    Nintendo knew what they were getting and they remained silent while IBM was blathering on about the non-existent connection to Watson.
  • »04.05.14 - 14:22
    > They didn't counter it either. Nintendo knew what they were getting and they remained
    That's true but still doesn't equal Nintendo endorsing the claims in my book. IBM is the maker of both Espresso and Watson/POWER7, so it's them who should know. There is no reason why Nintendo should care about what's in IBM's Watson and whether or how that relates to Espresso.
  • »04.05.14 - 16:29
    >they already announced the CTS-1000's successor with T4240...
    That would actually be interesting.
    The low cost PPC they were planning?
    No idea if that died on the vine.
    Do you think Power8 will supplant the PPC?
  • »04.05.14 - 17:13
    Yes, this thing.
    No, as the POWER8 *is* a PPC :-)
  • »04.05.14 - 18:55
    >Yes, this thing.
    Somebody has been spending time studying low cost ARM platforms.
    A valid point. Power8 is Power.
  • »04.05.14 - 19:19
    > http://www.itjungle.com/tfh/tfh042814-story02.html [...]
    > http://www.enterprisetech.com/2014/04/28/inside-google-tyan-power8-server-boards/
    No price mentioned, but OpenPOWER members can now order the SP010 reference board from Tyan:
    http://openpowerfoundation.org/blogs/blogpost1/
  • »17.07.14 - 10:45
    SP010GM2NR reference board now available from Tyan as complete system (Palmetto GN70-BP010) also for non-members for 2753 USD:
    http://www.tyan.com/newsroom_pressroom_detail.aspx?id=1648
    http://www.tyan.com/campaign/openpower/
  • »08.10.14 - 22:03
    Yasu
    Posts: 1724 from 2012/3/22
    Would that computer be even remotely useful in a MorphOS context, hypothetically? It's one thing that it's PPC, all components must nevertheless be port friendly to be useful to us.
    I could see myself buying one to run "MorphOS NG" on it though :-)
    [ Edited by Yasu 22.11.2014 - 01:16 ]
    My MorphOS blog
  • »21.11.14 - 22:14
    > [...] all components must nevertheless be port friendly to be useful to us.
    Apart from the POWER8 "Turismo" and accompanying Centaur chip from IBM, according to http://www.tyan.com/manuals/SP010_QIG_v1%200.pdf the major on-board peripheral controllers are these:
    - SATA3: Marvell 88SE9235
    - USB3: TI TUSB7340
    - GbE: Broadcom BCM5718
    Given that Ubuntu Linux is the recommended OS for this board/system, there should be open source drivers.
  • »22.11.14 - 00:51
    In_Correct
    Posts: 245 from 2012/10/14
    Linux is everywhere like The Plague. Port MorphOS to the new device instead.
  • »22.11.14 - 08:58
