Posts: 12074 from 2003/5/22
>> Interesting new project called
Libre-SOC: [...]
>> Details:
https://libre-soc.org/openpower/> New information from the company behind Libre-SOC:
https://systemeslibres.org>
https://systemeslibres.org/updates/just-incorporated/>
https://systemeslibres.org/updates/code_to_tapeout/Project to be presented at XDC 2020 in September:
https://xdc2020.x.org/event/9/contributions/607/Some questionable statements from the description:
The core processor design [...] is to be an augmented POWER9 compliant design"
Libre-SOC surely isn't to be a POWER9-compliant design, let alone an augmented one. It is, just like POWER9, to be a PowerISAv3-compliant design.
This [...] project [...] is also based on [...] the CDC 6600. With help from Mitch Alsup, the designer of the Motorola 68000, it has been possible to upgrade the 6600 core to multi-issue and precise exceptions with no architectural compromises."
According to
that web page, Alsup is a designer of the
ill-fated 88k, not of any 68k. The 68k designers are listed as:
68000: Stritter, Zolnowsky, Gunter, Leitch, Shustek, Tredennick, Crudele, McAlister, Crisp, Spak, Lee
68010: Zolnowsky, MacGregor
68020: Moyer,
Mothersole, Zolnowsky, MacGregor
68030: Boney, MacGregor, Moyer, Lamb, Vegesna, Rupp
68040: Shahan
68060: Circello
Edit:
slides available, fortunately without the above-mentioned claims
[ Edited by Andreas_Wolf 18.09.2020 - 14:03 ]
