OWB bugs
    VooDoo
    Posts: 189 from 2005/8/24
    Amigaharry2 wrote:
    Try to do following:
    After clicking login wait a some seconds, then click to the URL end delete the last sign (or item) and press ENTER.
    [ Editiert durch Amigaharry2 13.01.2014 - 17:14 ]
    Thanx for this ... now is working!
    A1200 sandwich
    uA1c/g3 800 mHz/256mb/160gb hdd/OS4.1 :-D
    Warp croatian Amiga portal :
  • »13.01.14 - 20:58
    Cool_amigaN
    Posts: 750 from 2011/11/30
    Hi, using latest OWB here and Vimeo's fullscreen button doesn't seem to be working. Anybody else can confirm this?
  • »14.01.14 - 21:02
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    It's a (paradoxal) consequence of enabing the fullscreen api, which was done to allow youtube html5 player to go fullscreen again.
    That said, i also provided a vimeo userscript since 1.21 to deal with that, which fixes the fullscreen mode. Just add it to the scripts manager.
  • »15.01.14 - 09:05
    Yasu
    Posts: 1724 from 2012/3/22
    @Fab
    Have you been able to reproduce the topsites bug I showed above? It seems to come at random. This time, I got two of those doing the same thing.
    My MorphOS blog
  • »19.01.14 - 23:40
  • Fab
    Fab
    Yasu wrote:
    @Fab
    Not on Morphzone, but apart from that, it's possible to have different thumbnail ratios, because they're based on the odyssey window size (it could actually be changed in the topsites_grid.html template file in resource/ if you know HTML/CSS well enough ;)).
  • »19.01.14 - 23:56
    Yasu
    @Fab
    It would make a lot of sense to have all the windows showing the exact same size as default, since they are basically previews. My 2 cents :-)
    My MorphOS blog
  • »20.01.14 - 00:07
    Yasu
    Here is another screen:
    Notice that the top left and the one below show the same homepage, but they look nothing alike. The bottom middle also looks strange as you can see, but for this screen I wanted to point out despite two homepages being the same, one can still be distorted.
    My MorphOS blog
  • »20.01.14 - 10:12
  • Fab
    Fab
    Well, this is a particular case, maybe you zoomed or the screenshot routine failed because of some frame. It looks like it's zoomed somehow in your screenshot.
    Anyway, more generally, what i meant is that the screenshot depends on browser dimensions (there's no relayout done to normalize it). So the width is always the same, but the height depends on the ratio. One could make them all the same width/height by clipping (by changing the grid template), but it's not ideal either.
  • »20.01.14 - 11:48
    Yasu
    Here is a HP that really eats up all my CPU and a lot of memory too:
    http://sadisticbutchering.com/game/
    My MorphOS blog
  • »09.02.14 - 23:58
  • rms
    rms
    Posts: 599 from 2004/11/27
    strange, I just tested this URL and it worked just fine for me, it did not eat up memory, neither did CPU. I went through all menues and did even play a portion of the video. Hmmm... strange
    Tested this on a Powerbook G4 1.67
  • »10.02.14 - 06:44
    Yasu
    @rms
    I tried again today. Removed all tabs, closed down OWB, started it again and went to that HP. CPU went to 100% for over 15 seconds, and memory dropped during this time from 793 MB to 362. Not until it reaced the lower level did the CPU drop to normal levels. Clicking on other links also drain the CPU for maybe 10 seconds, but memory don't drop below 200 MB.
    Maybe it has something to do with the G5? I have a G5, 2,7 GHz with a Radeon 9600 Pro 256 MB VRAM and 1 GIG RAM. I have not experience the same problem with other HP:s.
    My MorphOS blog
  • »10.02.14 - 13:04
  • rms
    rms
    Yasu wrote:
    @rms
    I just tried again and it still works fine, no problems at all, nearly no CPU load, and fast rendering... hmmm, yes perhaps it's a specific G5 problem? I can test in a few days on my G5 2.3 GHz and let you know.
  • »10.02.14 - 17:15
  • HAK
    Posts: 221 from 2003/2/24
    Hi Yasu,
    Hmm, on my G5 (2 * 2.5 GHz; Radeon 96000 Pro Mac&PC Edition) the page works without problem.
    Bye HAK
  • »10.02.14 - 18:48
    Yasu
    Weird. Maybe I got some setting wrong or something ..?
    My MorphOS blog
  • »10.02.14 - 23:59
    Posts: 1245 from 2010/1/6
    I've another issue: Useing www.conrad.at , OWB hangs during download data (waiting endless). Page is OK with Firefox or others.
    I'm sure that one of the older versions of OWB can show this page...
  • »13.02.14 - 08:46
    Posts: 12086 from 2003/5/22
    Issue discussed there:
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=9297&forum=16
    I'm quite sure it can't, unless you use pre-3.2 MorphOS.
  • »13.02.14 - 09:41
    Thanks - did'nt know about that...
  • »13.02.14 - 10:21
    Yasu
    I've found a bug.
    Go to this webcomic: http://www.ma3comic.com/
    Go to the bar below the comic to the left and click on it. You can only go up to comic #599 but not beyond.
    My MorphOS blog
  • »18.03.14 - 23:23
    igracki
    Posts: 389 from 2003/2/25
    If I use "Start Downloads automatically", then I don't get the "File already exists" requester!
  • »19.03.14 - 13:35
    In_Correct
    Posts: 245 from 2012/10/14
    I don't know what I'm doing wrong but sometimes the browsing history appears below the address bar and it won't go away.
  • »22.03.14 - 20:21
    Jambalah
    Posts: 820 from 2008/3/30
    @In_Correct:
    It's the autocompletion mode. You can disable it in Settings/Preferences/Interface/Url Completion Mode:
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »23.03.14 - 08:20
    In_Correct
    I will disable it. But please fix the bug. I think I figured out the mistake I made. Sometiimes I forget to click on the web page background and when I scroll using the arrow keys, the auto complete box appears but it won't go away. not even if I click a link on the page. It will go away if I click the links on the auto complete box. Perhaps a minor but still very annoying issue.
  • »23.03.14 - 23:56
  • Fab
    Fab
    The history popup is programmed to show if down is pressed when URL string is active.
    Anyway, you can just close it again with the related gadget on the right (or ESC, assuming you didn't configure ESC to quit MUI apps).
  • »24.03.14 - 10:47
    boot_wb
    Posts: 874 from 2007/4/9
    I think the bug in question is in whatever MUI class is used for autocomplete.
    When the autocomplete box appears, the only way to dispose of it is to select an item from the list, or to press return to use manually entered text instead.
    If return is not pressed (or an item selected), and the user decides to carry on browsing on the current page, or go to history menu, or whatever - the autocomplete box remains (it can actually end up hidden behind Odyssey's window if a double-click is used).
    Intuitive behaviour would be for the autocomplete box to disappear when cursor/focus moves away from the related text gadget (search box, etc).
    One (unrelated) minor annoyance I have is that menus & context menus seem to pause the rendering and network processes - media/page rendering stops (although playback continues if cached, just rendered video isn't updated) and downloading pauses completely until the menu is released.
    [ Edited by boot_wb 24.03.2014 - 13:04 ]
    www.hullchimneyservices.co.uk
    Windows free since 2011!
  • »24.03.14 - 13:59
    Yasu
    This is not a bug, but rather a small request.
    I like the topsites setting, but I would like it to be ready to overwrite as default.
    Now you have to klick on the address bar twice to mark "topsites://" and then over write it with a web address. I would like it that when you open a new tab and get the topsites, you can start writing a new address on your keyboard without having to klick on the address bar first.
    My MorphOS blog
  • »28.03.14 - 15:23
