Posts: 1476 from 2012/11/10
jPV,
I think you can save every image (including the background image) from a web page with WebInspector. Enable it from OWB settings and then you can RMB click page and select Inspect Element. Then select Resources and browse the web page tree to the Images.
Yes that works, it's a bit fiddly but it generally enables what I was after - strange way to do it, but hey, I'm happy enogh with that solution - Thanks jPV
By the way, the other Video contextual menu options are related to the Get Video scripts I believe, but I don't get watchable video from YouTube on my Mac Mini 1.5GHz even with the scripts - unless I'm doing something wrong.
The functionality of the mouse repeating it's signal once clicked and held down maybe a remnant of the way the Amiga used to operate, and hasn't been changed under MorphOS, but the PC and I seem to remember the Mac have this functionality.
I've found it useful, when I'm using the mouse on Windows or a Mac to be able to go quickly back to the top or bottom of a scrolling window to just click at the very top or bottom, and hold the mouse button down.
Of course the other suggestions when using OWB of using page up/down, or space bar, or backspace key are also worthy contenders, but don't answer the question as to the feasability of getting the mouse button to be able to handle the scroll bar in the way I've mentioned. Thanks all for your suggestions
