MUI4 for OS4?
    Intuition
    Posts: 1113 from 2013/5/24
    So anyway, MUI4 for Hyperion OS; as likely to happen as DirectX for Linux.
  • »23.06.13 - 11:05
    Posts: 2728 from 2003/2/24
    I remember that Fab said he wanted the abbreviation to stay the same (as opposed to what you seem to remember)
    You are completely wrong, I also remember this. And as usual you seem to miss the whole point by a mile or so, you always fail to see (or at least understand) the *message* behind the text (and no, not only in my posts).
    Changing a name of an application in order to simplify references to it in relation to completely separate applications, and to avoid confusion and unnecessary explanations as soon as someone mentions it (or the other application with the same name), becomes a completely pointless exercise if you use the abbreviation *as a name* (instead of the proper name) as soon as you make references to it, especially so when the abbreviation equals to both the old name and the name of the other application you wanted to distance from.
    Typing "Odyssey" isn't particular difficult, it's not a particular long word, it's not difficult to remember. There is *no need* to use abbreviations at all on that one, instead you could use the proper name directly, especially since the proper name has the benefit of avoiding confusion with the other, different application, which pretty much was the point in bothering with a new name in the first place. By using the abbreviation "as a name", instead of the *proper* name (regardless of version number, that's irrelevant), brings us back to square one, where people has to invent prefixes like "MUI-OWB" or "MOS OWB" or "OWB for MorphOS" to tackle the confusion, and it will always leave a few more or less ignorant people in the belief that "OWB on MorphOS" is a fairly useless browser since this is how "OS4-OWB" is.
    That's all!
    Now please don't make a mountain out of a molehill on this, Andreas!
  • »23.06.13 - 11:31
    Wow. That was a depressing read.
    Does everything in the Amiga community have to be disfunctional?
    I mean, is it some kind of requirement?
  • »23.06.13 - 11:38
    Intuition
    I take it that was rhetorical Jim? ;)
  • »23.06.13 - 12:15
    Posts: 12479 from 2003/5/22
    I don't think so. The only explanation as to why Fab chose another word beginning with "O" is that he wanted to keep the "OWB" abbreviation.
    Btw:
    "Posted By: takemehomegrandma [...]
    Fabien Coeurjoly has now released version 1.14 of his web browser, and also changed its name to Odyssey. Here are the highlights of the release: [...]
    Changed the name to "Odyssey Web Browser". Like it or hate it, but you can still call it OWB, anyway. :)
    https://morph.zone/modules/news/article_storyid_1882.html
    You remember what? That "probably the biggest reason [...] to the renaming of the browser Odyssey (06-Aug-2011) was to avoid the confusion with "the other" OWB's"?
    Let's see. Your point I was arguing was this: ""MUI-OWB" as they persist in calling it for some reason". Here you clearly criticize "them" (which is OS4 people as usual with your nonsense "messages") for calling the browser a name which you *later on* in the discussion admit has been coined by the author himself. Sane people would detract their imbecile accusations as soon as they learn of the truth, but you manage to keep the accusations up and *at the same time* admit that the responsibility for the confusion lies with the author. To me as a layman this sounds like a case of cognitive dissonance.
    On top of that, you play dumb by pretending that you don't know the reason for calling the browser "OWB" but you *later on* show that you clearly know the reason.
    You seem to fail at grasping a simple concept: to prove that your "message" is the usual bollocks it's necessary to reveal the single points your "message" is based on as the nonsense they are.
    You still don't get it, despite the fact that I explained it to you in plain and proper language. The full and proper name of OWB v1.9 is "Origyn Web Browser", as that's what its "About" window reads on both MorphOS and OS4. How would using that full and proper name help any distinction?
    Can you once and for all name the one(s) you think are responsible for "OWB" being the abbreviation of both the old and the new name? Is it "them" who "persist in calling it ["MUI-OWB"] for some reason"?
    Why do you expect others to use the name "Odyssey" for a browser that's cleary been named "Origyn Web Browser" by the author?
    How would using the proper name "Origyn Web Browser" help?
    How does the proper name "Origyn Web Browser" avoid confusion with those other, different applications?
    The new name "Odyssey Web Browser" was introduced with v1.14. The current OS4 version, which you were criticizing the inofficial name usage of, is a port of v1.9, so still "Origyn Web Browser" (see "About" window, regardless of OS). I explained that to you already, but "for some reason" you don't want to get it.
    And how do you suddenly know what Fab's point in renaming was when in your previous post you were still wondering about it?
    > By using the abbreviation "as a name", instead of the *proper* name [...], brings
    Using the proper name "Origyn Web Browser" for v1.9 wouldn't change that.
    No, it's not. If I start OWB v1.14 or above, the "About" window reads "Odyssey Web Browser". With versions below it reads "Origyn Web Browser". Why should anyone believe you of all people that the version number is irrelevant when the program itself says otherwise based on the author's decision?
    I'm merely replying to your nonsene. Stop it, and my replies will stop as well.
  • »23.06.13 - 12:37
    But Jesus H. Christ, Andreas!
    I think you'd better post some URL's now. Preferably a link to a link.
    Or a link to a link to a link.
    That would be good.
    Thanks!
  • »23.06.13 - 12:52
    I'm afraid you can't impress me with religious remarks. I trust in facts more than in believes :-)
    > Or a link to a link to a link. That would be good.
    Have you missed my link to the article about cognitive dissonance at Wikipedia? I don't know how more links would help with the topic at hand, but if that's what you need to weasel out I think I can help you. Which links do you want exactly?
    > Thanks!
    You're welcome :-)
  • »23.06.13 - 13:02
    XzIt
    Posts: 250 from 2005/1/19
    OMG ;P that was a big waste of time.
    Just one thing, why would we call anything be anything else but its real name ?
    So what ever fab has decided is the name, will stay the name for all time.
    Its like saying what ever you made, i can decide to rename...
    All Aboard Fail Boat, Lets Set Sail For FAIL! :-o
    X
  • »23.06.13 - 13:20
    Exactly. There's no point in using the name "Odyssey" for a browser clearly named "Origyn Web Browser". If you were more referring to the use of abbreviations, I think the primary motivation is language economy. I don't see anything bad in using abbreviations, especially if it doesn't cause any more ambiguity than using the "real name" would.
    Exactly. OWB up to v1.13 will always be "Origyn Web Browser", no matter how later versions are named.
  • »23.06.13 - 13:44
    Intuition
    > Is that the same Steven Solie that also promised an OS4-netbook ?
    It may also be the Steven Solie who "has re-written the "C" language to make it more Amiga efficient" ;-)
    My God these people are morons.
    The blind led by the blind!
  • »16.10.13 - 10:04
    boot_wb
    Posts: 874 from 2007/4/9
    Intuition wrote:
    Steven Solie has made the claim that Hyperion's OS is going to get MUI4 just like MorphOS has.
    Anyone know if this is true or is it yet more BS from him?
    http://forum.hyperion-entertainment.biz/viewtopic.php?f=36&t=1748#p20204
    "However MUI4 we have already, but it will go from 4.2"
    Comment 7 (from Samo79, OS4 betatester)
    (Google translation)
    [ Edited by boot_wb 17.11.2013 - 13:39 ]
    www.hullchimneyservices.co.uk
    Windows free since 2011!
  • »17.11.13 - 12:21
    "These go to eleven..." - Nigel Tufnel
    Oh well, at least sometimes the OS4 community is good for a laugh.
  • »17.11.13 - 16:09
    Minuous
    Posts: 163 from 2010/2/12
    Why not just port ReAction, which has been the official GUI since 1999, instead of always stressing about MUI?
  • »27.11.13 - 02:51
  • Fab
    Fab
    Posts: 1331 from 2003/6/16
    - Because it's too limited and awful to code with. Name us a couple relevant apps that are more than simple prefs editors or frontends? I can only think about Aweb itself... And maybe that OS4 dev tool. Anything else? Weird, isn't it?
    - Because MUI is the official toolkit in MorphOS, why should one bother about ReAction, when there's almost no app needing it anyway? And if one really wants, he can always install ClassAct classes on MorphOS anyway.
    - Is ReAction even "official"? I really wonder how one can consider 3.5/3.9 official. Piracy is also declared an official AmigaOS standard since they included a pirated TCP/IP stack then?
  • »27.11.13 - 03:53
    zukow
    Posts: 650 from 2005/2/9
    Yeah, Please, ask Hyperion to release the source code of Reaction. I don't know if Hyperion wants some cash for it but maybe 500$ will be ok considering its complexity.
  • »27.11.13 - 08:25
    XzIt
    Without Mui MorphOS wouldt exist...
    No mui = LOL
  • »27.11.13 - 10:50
    Minuous
    Well, I wouldn't call a program like AmiArcadia a simple prefs editor or frontend, it's AFAIK the most feature-complete emulator existing on MOS. With the possible exception of ports of generic multi-host emulators such as MAME.
    So someone made some libellous and presumably false allegation against H&P. Odd that it never went to court then if there was any substance to it. If they were a bunch of pirates do you really think they would have been running the Amiga No Piracy campaign? Various such allegations are always floating around the community in regard to most Amiga-related companies. Should I therefore believe the allegations floating around about Genesi stealing the AmigaOS 3.1 source code? According to your logic, I should. (Perhaps this explains the lack of OS3.5/3.9 support in MOS...) But I prefer to wait for hard evidence before jumping to conclusions.
    H&P were licenced by Amiga to produce these as official OS versions, so of course they are official. Anyway if one component of an OS is found to be in breach of some licence/contract, that doesn't mean the entire OS is suddenly unofficial. Eg. to use an example from a different platform, DoubleSpace technology in MS-DOS 6.0. According to such logic MS-DOS 6.0 is therefore unofficial...
    I guess compared to something overly complex and bloated like MUI it's simple, yes. I doubt Hyperion would want to sell a key technology like that to their main rival. However it maybe be possible to acquire ReAction source from H&P or from the original developers. (In fact perhaps H&P has uploaded it to some warez site, after all they are just a bunch of pirates supposedly.) Frankly there seem to be only minor improvements in the OS4 ReAction compared to the OS3.9 ReAction.
    [ Edited by Minuous 13.12.2013 - 21:40 ]
  • »13.12.13 - 10:26
    > [...] Various such allegations are always floating around the community
    > in regard to most Amiga-related companies. [...] I prefer to wait for
    Read there directly from the horse's mouth:
    http://web.archive.org/web/20050221085432/http://www.guru-group.fi/~too/amitcp.txt
    http://www.amigahistory.plus.com/amitcp392.txt
    http://www.amiga-news.de/en/news/AN-2000-12-00114-EN.html
    You can easily deduce these allegations as nonsense (unless they involve a time machine in Genesi's possession):
    - MorphOS development start: 1998
    - initial MorphOS release: 2000
    - incorporation of Genesi: 2003
    There is an easier explanation:
    https://morph.zone/modules/newbb_plus/viewtopic.php?forum=3&topic_id=9641&start=28
    > original developers. [...] there seem to be only minor improvements
    I don't know about the ReAction enhancements in OS4, but licensing an old ReAction version for MorphOS would surely result in a situation similar to the current MUI situation, only with the two operating systems reversed.
  • »13.12.13 - 12:38
    Intuition
    http://amigaworld.net/modules/newbb/viewtopic.php?topic_id=38546&forum=14
  • »24.12.13 - 19:49
    Wow, MUI, Odyssey, a little more work and they'll have....a slightly slower version of our OS (without Reggae, TinyGL, etc.).
    I thought we were the party accused of copying.
  • »24.12.13 - 20:02
    guruman
    Posts: 461 from 2003/7/21
    As far as I can tell, it is just a fork of MUI. Our MUI4 (I'd say, to avoid confusion, the only MUI4) is version 4.2, copyrighted 2012 by Stefan Stunz. Their is 4.0, copyrighted 2006 Stefan Stunz. I'd also say that the internals of MUI4, which were completely and heavily rewritten, are completely different for this release. As far as I can tell, these are most of the functionalities of MUI4 needed for Odyssey and MPlayer built on top of MUI 3.9.
    As often happens, the usual inferior copy of MorphOS functionalities somebody else has to live with... ;-)
    But feel free to correct me.
    Kind regards,
    Andrea
  • »25.12.13 - 12:59
    If this was Amiga.org or AmigaWorld someone would, then they would probably insult your penis size.
    But we tend to be above such silliness.
    Still, how is it again that we get accused of copying?
  • »25.12.13 - 13:48
    Yasu
    Posts: 1724 from 2012/3/22
    @Jim
    I don't know about that. I think a lot of MorphOS users have a sadistic liking of downtalking AmigaOS 4 (like in the thread in question). You either keep pounding in your points to those people, or you try to be the bigger person. You can't have both.
    My MorphOS blog
  • »25.12.13 - 17:24
    Intuition
    Becoz it teh reeel Jim! ;)
  • »25.12.13 - 17:39
