EUAE JIT
    pampers
    Posts: 1061 from 2009/2/26
    For G5 there has to be a fix applied so the JIT will be working. Looks like it will be done soon:
    You're welcome. But I have more in the pocket: The next MorphOS release will come with Video Overlay possibility, to gain more speed on CybergraphX (Further MorphOS versions had this feature and I want it back!). Even we think about a patched version for G5 computers, which gains some more clocks on certain commands. You will get my sources when I'm done with merging the code (Fab's code).
    Source:
    http://euaejit.blogspot.com/2014/01/ppcjitbeta01-morphos.html#comment-form
    MorphOS 3.x
  • »07.01.14 - 17:57
    Posts: 3 from 2014/1/8
    Yes, the G5 patch is not only for JIT.
    This Beta 1 doesn't have this G5 support at the moment. But we will include this in later releases (most likely Beta 2), so you can profit from more speed.
    Also in Beta 2 there will be video overlay for MorphOS E-UAE.
    For your Config problems:
    The cachsize must be between 0 and 16384. Note that JIT only will be active, if set. 0 and not supported values will turn the JIT off, resulting in a black JIT LED field.
    The switch "enable_jit" is not neccessary afaik as JIT will be activated when setting cachesize and a CPU which can use caches.
    amiga.use_overlay will be used in the next Beta.
  • »08.01.14 - 10:09
    pampers
    Funny thing is that the G5 problems were already mentioned: http://euaejit.blogspot.com/2012/10/jinxed-it-more-apples.html :)
    MorphOS 3.x
  • »08.01.14 - 22:56
    Posts: 12085 from 2003/5/22
    Indeed, and the solution has already been worked out back then:
    "Tobias Netzel [...] managed to fix up E-UAE for the G5 (PowerPC 970) processors. He got rid of the mcrxr emulated unsupported instruction [...] for this processor type. He also done some optimizations regarding the microcoded instruction usage [...]. [...] almost half of the emulated instructions make use of the mcrxr instruction for emulating some arithmetic flags. With the recent changes this PPC instruction is not used for anything if the emulator was compiled for G5 and the fix helps a lot on the interpretive emulation too."
    To me as a non-developer, this sounds like it just has to be compiled for PPC970 target and the alternative G5-optimized code should be used automatically for the resulting binary.
    Edit:
    "Performance of UAE used to be bad on G5 CPUs. The reason for this is the use of the "mcrxr" instruction which CPUs of POWER4 and later POWER architecture versions don't implement at all. For that reason OSes like GNU/Linux or Mac OS X/Darwin catch the illegal instruction exception that is thrown when that instruction is being executed and emulate it in software. That results in a huge performance penalty. That "mcrxr" instruction is used explicitely in the optimized flags code. Turning off flags optimization when executing gencpu will restore performance on those CPUs. Additionally I contributed code to FS-UAE and E-UAE PowerPC JIT that works around that problem."
    http://www.freelists.org/post/uae/Performance-on-G5-or-POWER4-and-later-CPUs
  • »08.01.14 - 23:26
    Yes, Andreas, this is what it should do. For this, there is a "define" to enable it. Unfortunately I don't have a G5 computer to test it, but now I found some ppl who will. So the Beta1 is strongly focused on the JIT implementation.
    But don't worry, there will be a G5 version with JIT.
  • »09.01.14 - 07:29
    Now there:
    "thanks to Fab the G5 executable is also available in the release package. [...] there were some murmur about the speed of the MorphOS version on G5 on some forums. No wonder: it needs a special version, which can be compiled from the sources for some time now. (Thanks to Tobias Netzel and to Fab for the special build.) Probably the same applies to the PA Semi processor"
    http://euaejit.blogspot.com/2014/03/ppcjitbeta02-beginning-of-beautiful.html
  • »15.03.14 - 10:25
    Jambalah
    Posts: 820 from 2008/3/30
    Cool news Andreas, thank you!
    Downloaded and tested a bit.... Fast, really fast on a G5 2.7 and it is also stable.
    Very good work.
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »15.03.14 - 13:39
    Posts: 165 from 2004/11/18
    I have tried, the 2nd beta on my 1.33ghz mac mini, but i have many sound interrupts when i want to play a game or a demo,
    The first version from fab, whitout jit has not this problemes especially on games. For demos like from elude the jit version seems to be twice faster in framerate but the sound is desapointing
  • »18.03.14 - 21:38
    > Now there: [...]
    The new beta doesn't come with a G5 built for MorphOS, unfortunately:
    "as it seems there is no official compiler with G5 support yet in the MorphOS SDK and it is rather complicated and unreliable to compile any source for that processor. Until this situation is improved the G5 version for MorphOS won't be available from the beta binaries."
    http://euaejit.blogspot.com/2014/05/ppcjitbeta03-switch-to-ludicrous-speed.html
    "The compiling for G5 is still not resolved for MorphOS, no G5-optimized binary again, sorry guys. If you could tell me how can I (easily) compile the files for G5 on my iBook then I give it a go, I promise."
    http://euaejit.blogspot.com/2014/07/ppcjitbeta04-fourfourfourfour.html
    Fab?
    Edit1: Fab did it
    Edit2: added beta 4 quote
    Edit3: Fab did it again
    Edit4: And once more
    [ Edited by Andreas_Wolf 11.01.2015 - 14:28 ]
  • »24.05.14 - 11:31
    weiseb
    Posts: 210 from 2003/3/29
    I am curios. Does Fab have his own gcc on Morphos or is he using cross compiling?
  • »24.05.14 - 12:01
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=10143&forum=9&start=1
  • »24.07.14 - 19:46
