EUAE JIT
    redrumloa
    Posts: 1424 from 2003/4/13
    waldiamiga,
    E-UAE JIT MorphOS First Beta
    Badass! I can't wait to get home and crank up the G5 to try this out!!
  • »03.01.14 - 16:25
    scrAb_
    Posts: 62 from 2010/7/23
    Installed on my PBook.
    It crashes every time I try to insert the floppy in the first drive with CTRL+ALT+F1....
    MacMini@1.5Ghz 1GB/DualBoot Morphos3.1/DebianPPC - Efika MX sb
    PowerBook 5,9
  • »03.01.14 - 17:03
    Well, they did say BETA.
    Nice to see another wish list item from Fraggle coming together.
    Since adopting my 933 MHz Quicksilver, I have upgraded to a system that is about 130% faster.
    At this point, my MorphOS system is marginally more powerful than my X64 system (and once both are upgraded, they will be at about parity).
    That, and this development, will make running the OS even cooler.
    MorphOS at 2.5 GHz, it just makes me grin.
  • »03.01.14 - 17:25
    pampers
    Posts: 1061 from 2009/2/26
    redrumloa,
    Let us know how it goes as I don't see any speed up on G5.
    Edit: I've checked on my 2.7 G5 - with Fab's EUAE.G5 I'm getting about 1.8 of A4000 speed with sysinfo, with this Jit Euae it's only 0.2 so the same speed as regular one. Also I've noted that it doesn't really like to work with directories as hard drive.
    [ Edited by pampers 03.01.2014 - 16:54 ]
    MorphOS 3.x
  • »03.01.14 - 17:41
  • k8o
    k8o
    Posts: 57 from 2013/5/29
    I used the beta and edited my config file as in the readme, i booted Classic Workbench 3.1 and launched some AGA demos such as TBL - Ocean Machine, and there was a significant speed-up! Very noticeable and things ran much smoother, good work! :)
  • »03.01.14 - 18:05
    Jambalah
    Posts: 820 from 2008/3/30
    Nice work!
    Though no luck to made him to work here...
    But hey, that's a beta and I did a really quick tries!
    Well, tomorrow I will enjoy this more.
    Keep calm and try again!!
    P.S. Inside the Read Me file there is a configuration option called "enable_jit=yes". Using it but it shows a "unknown config entry" message. Is it normal?
    [ Edited by Jambalah 03.01.2014 - 19:11 ]
    Pegasos II 1 ghz
    Powermac G5 dual 2.0 ghz
    Powerbook G4 1.67 ghz 17
  • »03.01.14 - 19:07
    pampers
    Jambalah wrote:
    Nice work!
    Are you sure you are using euae jit as there is no output for me at all..
    EDIT: I got 68 mips with sysinfo on my PB 1.67 with clean system. On my G5 (With Fab's G5 euae) I'm getting 35 mips. Holding a breath for fixed version of 1st beta for G5's
    [ Edited by pampers 03.01.2014 - 18:56 ]
    MorphOS 3.x
  • »03.01.14 - 19:51
    Jambalah
    @Pampers:
    Yes, I'm sure:
    -UAE 0.8.29-PPCJITBETA01
    Build date: Jan 2 2014 19:41:14
    Pseudo device open disabled
    Opening cfgfile '.uaerc'...okay.
    unknown config entry: 'enable_jit=yes'
    Timebase frequency: 33.750000 MHz
    Port "UAE" already exists!
    No disk in drive 0.
    Resetting frame rate hack
    Building CPU table for configuration: 68020
    1866 CPU functions
    Building CPU function table, 45674 opcodes (2 0 0).
    JIT: Building compiler function table.
    JIT: Allocation of translation cache...
    JIT: Translation cache size in prefs: 16384
    JIT: Allocated 16384 KB translation cache.
    AMIGFX: Using a 15-bit true-colour display.
    Sound driver found and configured for stereo at 44100 Hz, buffer is 17640 bytes.
    reset at 0
    JIT: Compiling reset
    JIT: Change cache emulation: disabled
    PAL mode, 50Hz (h=227 v=312)
    chipmem cleared
    SERIAL: period=372, baud=9600, hsyncs=16 PC=f8012e
    JIT: Change cache emulation: enabled
    B-Trap f201 at 00f80ca8 (0x3ad9afb8)
    Fastcard: mapped @$200000: 4MB fast memory
    Card 1 (ZorroII) done.
    Fastmem (32bit): mapped @$10000000: 16 MB Zorro III fast memory
    Card 2 (ZorroIII) done.
    Filesystem: mapped memory @$e90000.
    Card 3 (ZorroII) done.
    Line #5 unknown config entry 'enable_jit=yes' is trange though the jit led blinks showing jit is enabled and working. No way to make something work. The only way is to use more than 16384 for cachesize so to have an error and jit won't work. Workbench will be loaded but no way to use floppy.
    Pegasos II 1 ghz
  • »04.01.14 - 10:06
    pampers
    Weird then :) Did you try on G5 already?
    MorphOS 3.x
  • »04.01.14 - 10:37
    Norbi
    Posts: 99 from 2004/6/19
    Jambalah wrote:
    Nice work!
    from configuration.txt
    enable_jit=<boolean>
    if TRUE, use JIT compiling when it is possible.
    from README
    enable_jit=yes
    which version is correct?
  • »04.01.14 - 11:22
    Jambalah
    @Pampers:
    Real weird and.. I'm on G5. I will try later on MDD
    @Norbi:
    I tried with TRUE too but it doesn't work and prompt shows the same message. I tried command 'uae -h' and no enable_jit is showed inside all options.
    Pegasos II 1 ghz
  • »04.01.14 - 11:43
    Posts: 888 from 2004/1/24
    On my G5 2.3 it will load workbench from HD (only when the cachesize is set to16384, lower will crash quit EUAE while booting, higher stops the JIT from working)... only to crash quit when clicking on a drive icon. Shame :-)
  • »04.01.14 - 14:48
    Posts: 1915 from 2003/10/19
    Its a first beta and I understand that, but it seems very slow and unstable. Id say its more of an alpha. Im running it on a 1GHZ MDD with a radeon 9800 XT.
    Looking forward to the progress on this one! I use Amikit on my Mac a lot for now with very fast speeds. It would be nice to get all my Amiga stuff done on just the MOS side.
  • »04.01.14 - 15:20
    defender
    Posts: 248 from 2011/4/24
    I have tested the config as it is written in the readme file.
    Z3 mem crashes immediatly. Only clean WB 3.1 without gfx card starts.
    Typing commands is impossible because every letter repeats until
    You Typ another one. Well at least the jit light flickers.
    It seems we have to wait for the next beta.
    Greets
  • »04.01.14 - 23:25
    redrumloa
    I've had limited time to tinker, but it seems G5 support is not readly for primetime. My G5 is currently 2.0Ghz.
    In Sysinfo:
    E-UAE - 1.93 MIPS
    E-UAE JIT - 2.65 MIPS
    E-UAE.G5 - 17.27 MIPS
    E-UAE.G5 SDL - 18.34 MIPS
    E-UAE.G5 SDL is about 600% faster than current JIT on G5? Could that be right?
  • »05.01.14 - 22:43
    Intuition
    Posts: 1110 from 2013/5/24
    It's crashy as hell on my PowerBook but that is to be expected at this stage.
    edit: Scratch that, I set cachesize=32768 and my regular OS3.9 installation booted straight to Workbench without falling over despite the docs saying OS3.9 doesn't work.
    No Picasso96 UAEGFX screenmodes available though sadly so it's not quite as useful standard E-UAE.
    [ Edited by Intuition 05.01.2014 - 22:21 ]
  • »05.01.14 - 22:56
    Intuition
    On my PowerBook G4 1.67GHz
    Sysinfo 4 with E-UAE_JITPPC gives 33 MIPS
    Sysinfo 4 with Fab's E-UAE gives 15 MIPS
    Running e-uae.g5 on this G4 gives 19 MIPS.
    [ Edited by Intuition 05.01.2014 - 22:51 ]
  • »05.01.14 - 23:47
    Posts: 1 from 2014/1/6
    hello,
    can someone upload a config with jit
    thx
  • »06.01.14 - 14:31
    Intuition
    # path to filesystem (replace with proper path if needed)
    filesystem=rw,OS3.9:PROGDIR:HardDisks/OS3.9
    filesystem=rw,MorphOS_Work:Work:
    filesystem=rw,Work:PROGDIR:HardDisks/Work
    # path to hardfile (replace with proper path if needed)
    #hardfile=read-write,32,1,2,512,PROGDIR:workbench.hdf
    # path to kickstart file (replace with proper path if needed)
    kickstart_rom_file=PROGDIR:Roms/A4000Kick31.rom
    immediate_blits=no
    cpu_type=68040
    gfx_width=640
    gfx_height=512
    gfx_lores=no
    gfx_linemode=none
    gfx_center_horizontal=smart
    gfx_center_vertical=smart
    gfx_fullscreen_amiga=yes
    gfx_fullscreen_picasso=yes
    sound_bits=16
    sound_channels=stereo
    sound_frequency=44100
    cpu_speed=max
    chipset=ecs
    fastmem_size=0
    chipmem_size=8
    z3mem_size=128
    floppy_speed=800
    gfxcard_size=32
    # joy<n> where n is lowlevel unit in amigaos target. In SDL target it's be the enumeration order.
    joyport0=mouse
    joyport1=joy1
    # overlay display
    amiga.use_overlay=yes
    # screen type (accepted values are:public, custom or ask)
    amiga.screen_type=public
    enable_jit=yes
    cachesize=32768
    cpu_compatible=false
    cpu_cycle_exact=false
    blitter_cycle_exact=false
    comp_optimize=no
    comp_constjump=yes
    comp_trustbyte=indirect
    comp_trustword=indirect
    comp_trustlong=indirect
    show_leds=true
  • »06.01.14 - 18:13
    Jambalah
    I checked again this UAE-JIT and discovered that the only way to load floppy images for me is to set "amiga.floppy_path=MyFloppyImagesPath". In fact, if I use the Ctrl+Alt+F1 nothing happens. I inserted SysInfo adf hen just to benchmark and.. wow...
    http://img833.imageshack.us/img833/2200/nkbw.png
    Cook that RAM?!? I gues I can't cook an egg with this :P
    Obviously, no way to load workbench from hard disk...
    That black line in the bottom of the screen is garbage and I didn't managed to start UAE in window mode (tried "gfx_fullscreen_amiga=no | false | please | nope | f..k! XD!). Sometimes UAE stop running with an "JIT: Unexplained cache miss 0x2d10746c 0x2d10746c" error, sometimes it crashes.
    And it still prompt this unknown config entry: 'enable_jit=true' message, though led is green/active.
    @Intuition:
    If I set "cachesize=32768" jit led stays black (=not active). ..???..
    Pegasos II 1 ghz
  • »07.01.14 - 15:01
  • vox
    vox
    Posts: 524 from 2003/11/25
    Fraggle wrote:
    I have decided that I want MOS to win :D
    Wow! Thanks. Especially for people who have made possible to use JIT
    on MOS UAE. As I figure it out, low-end systems should benefit more.
    Will it be possible to emulate vanilla A1200 on G3 1GHz system *I count SAM460ex to be about that performance
    Lame PC with AmiKit XE
  • »07.01.14 - 17:28
    pampers
    For G5 there has to be a fix applied so the JIT will be working. Looks like it will be done soon:
    You're welcome. But I have more in the pocket: The next MorphOS release will come with Video Overlay possibility, to gain more speed on CybergraphX (Further MorphOS versions had this feature and I want it back!). Even we think about a patched version for G5 computers, which gains some more clocks on certain commands. You will get my sources when I'm done with merging the code (Fab's code).
    Source:
    http://euaejit.blogspot.com/2014/01/ppcjitbeta01-morphos.html#comment-form
    MorphOS 3.x
  • »07.01.14 - 17:57
    Posts: 3 from 2014/1/8
    Yes, the G5 patch is not only for JIT.
    This Beta 1 doesn't have this G5 support at the moment. But we will include this in later releases (most likely Beta 2), so you can profit from more speed.
    Also in Beta 2 there will be video overlay for MorphOS E-UAE.
    For your Config problems:
    The cachsize must be between 0 and 16384. Note that JIT only will be active, if set. 0 and not supported values will turn the JIT off, resulting in a black JIT LED field.
    The switch "enable_jit" is not neccessary afaik as JIT will be activated when setting cachesize and a CPU which can use caches.
    amiga.use_overlay will be used in the next Beta.
  • »08.01.14 - 10:09
    pampers
    Funny thing is that the G5 problems were already mentioned: http://euaejit.blogspot.com/2012/10/jinxed-it-more-apples.html :)
    MorphOS 3.x
  • »08.01.14 - 22:56
