How to get at NAS disk to work with MorphOS?
    TheMagicM
    Posts: 1217 from 2003/6/17
    That's the EXACT NAS I have. Trying to do the same thing.
  • »08.06.13 - 17:21
    amyren
    Posts: 219 from 2010/5/15
    TheMagicM,
    Let me know if you find a way to mount it on MorphOS
    Its a good disk, but I had some stating troubles though.
    First I did connect it and tried to use FTP to transfer the content from my 500GB WD USB disk. There was about 450GB of data on the disk, but before transfering half of this, the GoFlex ran out of space. Also I was unable to delete certain folders on the drive after this.
    Then I tried to format the drive uising the webinterface. But this reported an error, failed to format the disk. After this the disk was unreadable, so I had to dismantle the hdd in order to connect it to a SATA interface on a pc. (standard SATA connectors wont fit directly because of the casing gets in the way). This was an xp pc, so it after formatting it, my 3TB disk was now only 750GB. Then I downloaded some files to extend xp to support up to 2TB. So now I only have 2TB of my 3TB disk available, since I didnt have a vista/win7/8 pc with sata available at the time.
    The disk works fine as a hdd for my dreambox, and as a network mounted drive on my xp and win8 pc. Also my DAB/Network-radio detects the drive out of the box and plays audio from it. My raspberryPi (xbmc) mounts it and works great with the drive. So all in all I'm quite pleased with it.
    My only complaint is the format utility from the webinterface.
  • »08.06.13 - 18:50
    roschmyr
    Posts: 206 from 2003/2/20
    @amyren
    did you add the adress of the NAS to the host list -> MorphOS preferences - Hosts
  • »08.06.13 - 19:06
    TheMagicM
    Ok..I did a test scenario..
    I created a SAMBA share (smb) on my server..mapped it just fine..
    Then I started looking at the GoFlex...well, I dont have SAMBA as a option, its cifs. Two different things and thats why I believe its not working. SMB protocol and cifs are two different things.
    [ Edited by TheMagicM 08.06.2013 - 19:44 ]
  • »09.06.13 - 01:43
    sonter
    Posts: 12 from 2012/6/24
    Back to the question in hand, which is mounting the samba share at boot. The line WaitForPort NETSTACK worked fine before I added the Wifi card, but afterwards the script failes. I assume its because it no longer waits until the network is up and running. script works fine once i run it myself manually.
    [ Edited by sonter 09.06.2013 - 10:16 ]
  • »09.06.13 - 09:16
    Posts: 12080 from 2003/5/22
    Not quite true. CIFS is a superset of SMB (which makes SMB a subset of CIFS). This means that in theory (i.e. if correctly implemented), the entire SMB protocol should be included in any CIFS implementation. So connecting with an SMB client to a CIFS server *should* work. In real life however, we know that there can even be compatibility issues between different SMB implementations.
    "Microsoft launched an initiative in 1996 to rename SMB to Common Internet File System (CIFS), and added more features, including support for symbolic links, hard links, larger file sizes, and an initial attempt at supporting direct connections over TCP port 445 without requiring NetBIOS as a transport (a largely experimental effort that required further refinement)."
    http://en.wikipedia.org/wiki/Server_Message_Block#History
  • »09.06.13 - 09:25
    Nadir
    Posts: 157 from 2003/3/17
    Your stack is up at that stage but you are not yet online with the wifi card. You could try waiting for WLANMNGR_GLOBAL instead but I'm not sure if this will be enough either. The safest would probably be to ask the stack if you have a connection to your NAS or router (this can be done via the ARexx interface)
  • »09.06.13 - 11:34
    TheMagicM
    Andreas_Wolf,
    theoretically it should work..why its not, I dunno. I know that I have a SMB share on my server and I can map it, but this Seagate GoFlex I cannot. Strange.
  • »09.06.13 - 12:45
    TheMagicM
    Is there a way to NOT have IconX pop up when clicking on this script? Like a "/quiet" option so I dont see the window?
  • »09.06.13 - 13:07
    sonter
    Im a bit of a beginner on MorphOS so im not quite sure what the ARexx interface is? a quick search through Grunch told me it was installed though
    Adding the line WaitForPort WLANMNGR_GLOBAL didnt help either
    [ Edited by sonter 09.06.2013 - 15:44 ]
  • »09.06.13 - 14:14
    Nadir
    Many MorphOS applications and other software components communicate via such an interface. It basically means that the user can control the software from a script/commandline (or from another software component). NetStack has a large interface that allows you to control and get information plenty of stuff so it is surely possible to check if your NAS is up and happy. However, I don't have a ready solution for you...
  • »09.06.13 - 18:59
    bash64
    Posts: 934 from 2010/10/29
    SMB and CIFS are not two different things.
    They are the same thing, for all intensive purposes.
    CIFS is just the newer version of SMB.
    After a certain point SMB was renamed to CIFS.
    I handle SMB all day long at work.
    Admittedly SMB is much older and is mostly 95/98 compatible.
    Place the NAS in CIFS mode and you should be able to mount with the amiga copy of smb.
    You can run into issues though if you choose the wrong mode.
    You do NOT want NTLM v2. This requires SMB 3.something to work. Stick with NTLM v1.
    "User" or "share" mode should be ok.
    Do not use anything to do with servers like NT or AD modes.
    If you can post a pic of the CIFS settings screen I will have a look.
    [ Edited by bash64 09.06.2013 - 14:19 ]
    Powermac G5 2.3ghz 2GB, ATI 9600 Pro
  • »09.06.13 - 19:19
    TheMagicM
    no such thing I know of as settings to post in this GoFlex... doesnt matter too much for me since I have a server running FreeNAS that works well.
  • »09.06.13 - 19:48
    Ingo
    Posts: 103 from 2004/3/20
    Yes, if you "run >nil: smbfs <stuff>" there should be no window.
  • »10.06.13 - 10:27
    TheMagicM
    @Ingo: thanks!
    ...back to the GoFlex..yea it is a weird NAS. I had to ssh into it to change the funky default share names, otherwise out-of-the-box, you cant change share names.
    Anyway, I can map my server's SAMBA share just fine. I'm planning on moving away from that proprietary piece of shit Seagate GoFlex to my FreeNAS setup, so I'm going to skip on figuring out the GoFlex.
  • »11.06.13 - 02:28
    Posts: 1031 from 2004/9/23
    roschmyr wrote:
    @amyren
    This one isn´t needed if you use the name defined in NAS settings.
    e.g. if you want to connect to a windows system named "pentium", just use this line:
    run <>NIL: smbfs cache=12288 workgroup=MSHEIMNETZ service=//Pentium/SharedDocs/ volume=SharedDocs
    This also allows the NAS to run in DHCP mode, as you don´t need to know the IP.
    Geit
  • »06.08.14 - 09:44
  • rms
    rms
    Posts: 599 from 2004/11/27
    geit wrote:
    roschmyr wrote:
    @amyren
    Geit
    @Geit
    i managed to mount my NAS (it's a QNAP QTS T269) with smbfs on MorphOS but when I copy files to it I don't get more then about 3 MB/s. I tried with one single 1 GB file, which takes aver 5 minutes to get copied.
    I used the same cache value, 12288, you mentioned above. Can this value be increased, if so to what value, and would it help to get faster transfer?
    Any idea?
    Christoph
  • »19.11.14 - 08:27
    Posts: 1238 from 2010/1/6
    Same here......smbfs is very slow - only usable for small files....
    Better use FTP, if possible.....
  • »19.11.14 - 10:40
    catohagen
    Posts: 297 from 2003/5/20
    smbfs is fast enough on a mounted nas, here i've mounted a Dlink-323 nas on Morphos and copy a linux iso with average 14-15 megabyte/s
    https://www.youtube.com/watch?v=4FlsmCctSrg
  • »19.11.14 - 11:09
    That may depend on Roadshow! With normal MOS 3.7 installation on PEG2/1GHz the best speed I got, was about 5-6MB/s....
  • »19.11.14 - 12:27
    catohagen
    Netstack was upgraded in recent Morphos updates and should give comparable transfer rates to Roadshow.
    With a Powerbook G4 hocked up to a gigabit switch, Roadshow peaked at 33-34 megabytes/s copying a linux iso, using 68k samba 2.2.5 (not smbfs)
    This was from ramdisk to win7
    Morphos ram disk was accessed as a samba share on a Win7 pc connected to the same switch and I copied this linux iso both ways, transfer rate to ramdisk was over 25 megabytes/s, but I guess Morphos read/write performance differs on high network activity.
    With the new Netstack now in Morphos, one morphos dev (piru?) got 45-50 megabytes/s on local FTP transfers.
  • »19.11.14 - 13:39
  • rms
    rms
    well, I use a PM 2.7 GHz and when I copy from MorphOS to the NAS, I get a max speed of 3 MB/s, though from the NAS to MorphOS I also get 15 MB/s using smbfs. I tried to a hd partition and also RAM which gives the same result.
    3 MB/s for uploading files is definitely to slow to work with the NAS, just not usable! But 15 MB/s or even more would do it. So the question is, what is going wrong or why it's only possible to dowload from the NAS with a 15 MB/s speed?
    Any idea?
  • »20.11.14 - 06:37
    connor
    Posts: 570 from 2007/7/29
    @ catohagen
    but FTP is not Samba. There must be a reason why Samba is so slow. I also have very low speed.
  • »20.11.14 - 17:29
    catohagen
    connor wrote:
    @ catohagen
    In my case, Netstack was always slow so when Roadshow68k was released I did some tests with Roadshow and adjusting and tuning parameters on both the stack and samba, transfer speeds flew up.
    Roadshow had tcp send and recieve buffers as a very low number as default, as the stack was ported from Freebsd stack from the 90's when dialup modem to connecting to internet was normal. Just adjusting the tcp buffers to 32768 or higher will probably help (on Roadshow) Roadshow also have some implementation of tcp window scaling, that helps alot.
    Samba also have parameters you can adjust, setting the tcp buffer to 8192 might help, and Im sure I adjusted some register values on Windows7 that had effect.
    On my nas, i downgraded Samba there to an older version, and adjusted buffer values aswell. Samba on linux I guess are more resource hungry on later versions, installing a 2.x.x improved transfers.
    For Roadshow, i wrote an arexx installer that had options for adjusting the different parameters based on your network, the installer also helps turning on/off or switching betweeen Netstack and Roadshow as tcp stack...
    Atleast in my case, both a Mac mini and Powerbook G4 with Roadshow 'maxed out' on network performance between a Win7 machine and Samba68k 2.2.5 server on Morphos 3.2, getting 9-10mb/s on the 100mbit ethernet on Mac mini and over 30mb/s on the gigabit ethernet on the Powerbook G4, copying files back and fourth.
  • »20.11.14 - 23:35
