MorphOS Developer
Posts: 1031 from 2004/9/23
klesterjr,
It also seems to keep losing the time zone (I think, anyway -- date is always correct, but the hour is always off by a few). I haven't noticed any problems on the Mac side, but I'm wondering if my pram battery is dead/dying. Does MorphOS "require" a functioning pram battery?
Well, between MorphOS and MacOS the time is different by one hour, AFAIR. I just use SetClockNTP, so the time gets set each time the system boots.
klesterjr,
I also noticed that def_icons don't have a second state! Is there a setting somewhere that I missed? Perhaps something I can put in the Ambient advanced pref file?
You need to enable the png double icon option in ambient->icons.
Geit
